yoke and pinion seal replacements?
Old Jun 29, 2010 | 11:44 PM
  #31
Highway 4x4's Avatar
I gave in and had a dealer do my front seal under warranty. I ran it a few miles to see if the diff was OK then put in the Dynatrac hub kit. All done forever.
Old Jul 3, 2010 | 06:48 AM
  #32
neversatisfied's Avatar
Originally Posted by neversatisfied
Is the seal installed dry or with some lube on the lip? Tech told me these seals are teflon and should be installed dry. All previous installed seal I have put in were put in with grease on the lip.
ANY HELP also what is the torque on the diff. cover bolts?
Old May 17, 2012 | 05:45 PM
  #33
maddog1927's Avatar
Originally Posted by Bubbubouy
As CRXsi mentioned, I can’t imagine why you would need to replace the yokes unless you have been using the truck for mudding. In that case sometimes dirt will get between the seal and the machined surface on the yoke and polish a groove in the yoke, in which case the new seal may leak immediately or very soon after replacement. Otherwise you can continue to use the yoke.
As for the question of replacing the pinion seal, there are two different methods of setting the pinion bearing preload on any differential of the size and style in your truck. One method is with a crush collar (one time use), and the other is with shims. I have been rebuilding differentials for many years and have only seen crush collars used in small axles such as what would be in the front of a jeep.
Dana 60, 70 and 80 all use shims. I have not yet been inside any of the AAM differentials but I would hope they would use shims.
If you have an axle with the pinion bearing preload established with shims you can just torque the pinion nut to specifications after replacing the pinion seal.
If you have an axle with a crush collar (or you don’t know for sure) use the following procedure.
1) Remove driveshaft
2) With a chisel or cut-off wheel on a small grinder make a line across the nut and the end of the pinion.
3) Remove nut, washer, and yoke
4) Remove pinion seal
5) Install new pinion seal
6) Install yoke
7) Clean threads with brake clean
8) Apply Lock-tight to threads
9) Install washer and nut
10) Tighten nut until your marks line up and you are done
Sorry for being so long winded, this is an easy job but needs to be done correctly. I have seen too many mechanics just use an impact until the nut won’t tighten any more and call it good. This is the difference between an axle that lasts 50,000 miles and 150,000 miles.
Looks to me like this method is way easier than the way it says to do it in the service manual. Also seems like those who have had it done by the dealer, have got this method NOT the one in the service manual. Mine is leaking, I guess I will do it this way.
Someone mentioned they felt that synthetics diff oil leaks. Mine happens to be synthetic oil, could there be anything to that? Trying to decide what to put back in.
Old May 17, 2012 | 09:44 PM
  #34
Adaminak's Avatar
They're all synthetic fill from the factory, and I'd strongly recommend you stick with synthetic. As far as synthetic leaking more than conventional, I think that's a wives tale that may have been true in the 70's when conventional oil lasted 30K miles before it turned back into dinosaur bones, but oil formulations have come a long way, and gear lube is still pretty darn thick. I don't believe it's an accurate assessment any longer...
As far as refill, I just swapped to Amsoil because it was available, but I've previously run the Schaeffer's 293 w/moly and everything looks as clean and pretty as it was new...
Old Jun 1, 2012 | 10:34 AM
  #35
maddog1927's Avatar
yoke Shaft has a deep groove, from sand at glamis I am sure.
Looks like there is not a speedi sleeve for this size. The OD of the shaft is 2.110 in.
http://vsm.skf.com/en-US/HeavyDuty/K...eb_secure.ashx
I got a new yoke $133 account discount and taxed.
I really don't like the idea of putting a new yoke in, since I took the short cut of marking the shaft and nut and counting how many turns of the nut method, but really my only good option at this point.
DodgeCowboy
Mar 14, 2008 12:53 PM
pwrtripls1
Jan 7, 2008 08:55 PM
Texaschevelle
Oct 7, 2007 10:08 AM
dieselcarpenter
Sep 18, 2007 06:01 PM
