WOW! What an alignment!!
Old Apr 1, 2008 | 10:15 AM
XLR8R's Avatar
Exactly!
"Crabbing", I believe, is the technical term...
Old Apr 1, 2008 | 11:28 AM
lniemeyer2's Avatar
Just a little more info none of my friends ever noticed my truck crabbing but no one was ever really looking for it so it was not real apparent appartently and another note my tires have wore like iron I'm at 72,000 on my stock Michelins and they have no wear issues and expect another 10,000 at least out of them.
Old Apr 1, 2008 | 11:53 AM
RBulldogger's Avatar
Originally Posted by cscott67
If the rear axle is not aligned correctly it looks like the truck is going down the road sideways while traveling forward. Scott
All the lifted Chebys look like that around here.
Old Apr 1, 2008 | 06:36 PM
chipmonk's Avatar
do you notice it driving/handling any different since having the thrust angle corrected?
Old Apr 1, 2008 | 06:39 PM
rjm022's Avatar
if your axle was not aligned-even a tad bit off- anybody following behind you would notice it- even if they were not "paying attention" you could not miss it! it the rear end of the truck would be tracking side ways!!. i agree- something fishy there.plus- you should of had some major tire wear, if the axle was not aligned.
Old Apr 1, 2008 | 06:43 PM
chipmonk's Avatar
would you definitely see uneven tire wear if your thrust angle was out of spec?
Old Apr 1, 2008 | 07:03 PM
TreeFarm's Avatar
Originally Posted by XLR8R
Exactly!
That's the newfangled term. Old hands call it by what it is, dog walking.
Old Apr 1, 2008 | 10:22 PM
torquefan's Avatar
No, I can't say you'd see tire wear. Generally, you would get a pull to one side or the other, and it may be noticeable to other drivers following behind you, but I've aligned vehicles with a thrust angle of up to .3 degrees that showed no symptoms, and no complaints from the driver. If the thrust angle was something that happened suddenly, the main complaint would usually be a steering wheel that's no longer straight.
Old Apr 2, 2008 | 01:45 AM
nelrod's Avatar
IMHO it was money well spent. Sounds like they earned it. I would not worry about it and enjoy driving your lined truck. JMO thoughl.
Old Apr 2, 2008 | 05:48 AM
Swayse's Avatar
I've always called it bulldoggin. For me, the easiest way to line it up in the back, just look across the sidewall of the back tire, and line it up with the front sidewall.
Old Apr 2, 2008 | 10:10 AM
lniemeyer2's Avatar
It seem like the steering is easier to turn now and a little "crisper", free, or quicker for lack of a better term. Regardless I'm just glad everything is straight now.
Old Apr 2, 2008 | 10:35 AM
Baja's Avatar
[QUOTE. So far my "cheap" $330 leveling kit has cost me about a grand to get everything right. What a simple project this turned out to be![/QUOTE]
Like something like that has never happened to me (or anybody that has worked on cars/trucks). Can't wait to post the results of my "cheap, easy, quick, simple" front axle seal replacement!
rbrettctd
Nov 11, 2008 01:42 PM
roadgeneral
Oct 17, 2007 06:54 PM
Shawn.L.Turbo
Jul 16, 2007 06:21 PM
getblown5.9
Dec 18, 2005 08:28 PM
