wont idle down
Old Nov 16, 2008 | 02:57 PM
hauliday's Avatar
wont idle down
I have an 03 2500 w/ 6 speed when you rev it up it will stay at or about 1000 rpm and stay there for30 or 40 seconds unless you let out the clutch and pull the engine down but if you speed it back up it will stay there. I reset the tps did not help then replaced the tps still did not help there are no codes and everything else seems normal any suggestions?
Old Nov 16, 2008 | 11:59 PM
ram4tow's Avatar
Im curious about this too.. my friends 2003 6speed did the same thign when i was driving it.. maybe its normal..
Old Nov 17, 2008 | 08:37 AM
hauliday's Avatar
Well i hope not
Old Nov 17, 2008 | 08:41 AM
06RAM2500's Avatar
IIRC, injectors are in need of a checkup
Old Nov 17, 2008 | 10:23 AM
buralcat's Avatar
i have an 03 5spd. and it does the same thing. i can get it to idle down with the clutch, but i can also get it to idle down by holding in the brake. i am pretty sure my injectors are in good shape
Old Nov 17, 2008 | 11:47 AM
jhenson's Avatar
Exact same symptoms with my '03. However, I don't have the money it takes for replacement injectors. She still gets about 22 on the highway so I'll just leave her alone.
Old Nov 18, 2008 | 02:40 AM
BigIron70's Avatar
Cummins Guru
Inspect the engine wire harness near the a/c pressure transducer for damage. These wires have been known to short out and cause problems.
Old Nov 18, 2008 | 06:42 AM
hauliday's Avatar
Ok thanks it worth a shot
rustydeeretech
Jun 16, 2010 09:41 AM
Stroked-Z
Oct 4, 2008 11:28 AM
DAN POUCHER
May 7, 2008 07:23 AM
01smoker
Oct 30, 2007 03:25 PM
Rpainter
Jul 21, 2007 08:48 AM
