won't crank
Old Aug 28, 2010 | 03:08 AM
jwatso8's Avatar
won't crank
i have and 07 2500 5.9L with a manual. i when out after work to start my truck and NOTHING! won't even crank. turn the key and nothing. no clicking, no cranking. is the clutch switch on the ground side of the circuit? i checked it with a test light and nothing so it makes to believe its on the ground side. or im not getting any power the clutch switch. does anyone have directions on checking the ignition and clutch switches? doesn't the key have a computer chip in it? could that not cause it too? thanks, its going to be a long weekend without wheels!
Old Aug 28, 2010 | 08:47 AM
FMB's Avatar
FMB
Originally Posted by jwatso8
... turn the key and nothing. no clicking, no cranking. ...
BTDT, but it wasn't the clutch switch, it was a shorted wire to the starter blowing the starter relay fuse. Check this thread for details, pics and easy fix.
Back to morning brew . . .
Old Aug 28, 2010 | 04:22 PM
jwatso8's Avatar
thanks FMB i checked that, but thats not it. so here's what ive done. checked the ignition fuse-good. no codes. bypassed the clutch switch. my question is where is the relays on this truck? thanks
Old Aug 28, 2010 | 05:42 PM
BigIron70's Avatar
Cummins Guru
Read TSB may apply to no start problem.
Old Aug 31, 2010 | 11:46 AM
jwatso8's Avatar
THANKS BigIron70 i think that fixed my truck. its now starting. thanks
Old Sep 1, 2010 | 10:19 PM
BigIron70's Avatar
Cummins Guru
Glad to hear, have a great Labor Day weekend.
92smokin blacky
Feb 28, 2011 02:36 PM
ado2b1
Dec 16, 2008 03:19 PM
Machinos
Mar 16, 2008 01:34 AM
aaronedwards82
Jan 14, 2007 09:07 AM
PaulDaisy
Dec 2, 2006 12:36 PM
