Wix Air Filter...is it me or ???
Old Oct 31, 2007 | 07:37 PM
Tiara3100's Avatar
Is it me or do the Wix Airfilters last longer the then Fleetgaurd Filters?
I installed a Napa Gold/Wix (Part #42846) airfilter in my truck a few months back and my filter minder has barely moved. I checked for air leaks and switched filter minders with my buddy. Everything seems good.
I would have to replace my Fleetgaurd filter every 3-4 months. I have to wonder if it's filtering as well as the fleetgaurd or if it's just built better.
Old Oct 31, 2007 | 09:21 PM
iweb's Avatar
I think you are right, I have 30K on my truck and just 5K miles ago I changed to wix and now my minder does not move and with stock it was in the red all the time.
Old Oct 31, 2007 | 09:37 PM
surfram's Avatar
I have been using Napa Gold 2846 (Wix) filters for almost 70,000 miles. I usually change every 15,000 but I have gone over 20,000 without the filter minder moving. They are rated at 675cfm.
Old Oct 31, 2007 | 09:43 PM
Minwy's Avatar
In the Dmax filter test that's posted on different sites, wix filters was one of the worst (paper filter) for letting dirt through, that would account for a longer life. Also for my self anyway, the Fleetguard cost me $6, napa filter $35. No contest.
Old Nov 1, 2007 | 02:30 AM
chipmonk's Avatar
the filter minder is not the way to judge filter quality or when it needs to be changed. i've seen the original mopar filter completely black and filthy in bad need of changing and the f/m had'nt moved while the day after i put a clean filter in my aem intake the f/m is sucked down. with performance intakes and filters the f/m gets pulled down quickly and easily due to the venturi effect and not because of airflow restriction.
Old Nov 1, 2007 | 07:10 AM
Swayse's Avatar
Wix filter has much longer pleats than the baldwins I was using before. Brand new baldwin would suck down the filter minder 30 to 40 percent. My Wix has been in there awhile, and is now just starting to suck down.
I'm all about the Wix
Old Nov 1, 2007 | 08:10 AM
firecrazy720's Avatar
where are you getting the fleet guard for 6 bucks at ?
Old Nov 1, 2007 | 02:23 PM
Tiara3100's Avatar
Yea...where are you getting Fleetgaurd filters for $6!!!!!
I get the wix filter for about $14-16 online. Napa will charge you about $26 for the same filter.
Old Nov 1, 2007 | 03:36 PM
Spooler's Avatar
The best thing to of done is an oil analysis using the stock filter for 5,000 miles and then change the oil and run the Wix for 5,000 miles following both with an oil analysis. Comparing the 2 you could see exactly how much dirt was passing through because it will end up in your oil..........I would use the fleetguard if I still had my stock box.
Old Nov 1, 2007 | 03:48 PM
coparam4x4's Avatar
Amsoil all the way....Good for 100k
Old Nov 2, 2007 | 07:05 AM
Minwy's Avatar
Local Cummins dealer is where I buy my filters. I about died when I bought my first and only filter from the local Napa dealer for $35. There is a huge markup on filters, and they can be sold cheap if the dealers would choose to do so. I put an amsoil in this last time to try and its starting to pull the indicator in after only about 5k miles. About the same as the Fleetguards I was running.
Old Nov 2, 2007 | 08:06 AM
Totallyrad's Avatar
My local Cummins dealer's parts guys are...........less than friendly when you start asking questions that contain the word Dodge. Would you mind posting the part numbers, please?
Old Nov 2, 2007 | 09:15 AM
OOPS's Avatar
This is the key reason they last longer. They do not filter as well.
jlipskoc
Mar 14, 2011 03:37 PM
Dalbery
Nov 22, 2006 07:27 AM
gnarlykaw
14
Feb 22, 2006 09:48 AM
MOAGGIE
Jul 12, 2005 07:50 PM
sshelly
21
Aug 22, 2003 08:58 AM
