Will this help my mileage?????
Old May 14, 2008 | 09:27 PM
snoyes's Avatar
Yes it does, hence in the city you may see a little worse fuel mileage from all the starts. On the highway, since you do not have to expend the energy getting the bigger tire up to speed from a dead stop, you can benefit more from the lower RPMs it gives you at highway speeds.
Old May 14, 2008 | 10:10 PM
memphis04's Avatar
So if I can recalculate the speedometer these 315's might work to my advantage?
Old May 14, 2008 | 10:13 PM
snoyes's Avatar
Yes, right now your odometer is reading you travelling less miles than you actually are. If you make the adjustment to correct it, you should see an approximate increase of about 10% in what you are getting for your fuel mileage right now.
Old May 14, 2008 | 11:21 PM
Tiara3100's Avatar
Just took my 315's of and re-installed stock 265's and my Mileage went down. (Speedo re-calibrated both ways and hand Calculated) I would put the 315's back on, but it's camping season and the 315's are only load range "D" and my 265 stockers are "E" rated...
Old May 15, 2008 | 03:52 PM
Mark Hodowanec's Avatar
Originally Posted by memphis04
I have a set of 315 70's on the truck and my mileage did suffer from them, but heres the question. Do yall think my mileage will go up any if I took off the 315's amd put 285 70's on it instead?
I think that it depends on the tire. With aggressive the milage will go down. W/ more reasonable all terrains the milage will go up. Iwent from the stock 265s to 315 BF Goodrich all terrains, my milage went up 1 mpg. When those wore out, I replaced them w/ Hankook 315 mudders. They were even load e rated. The milage went down 1 or 2 mpg. Toyo now make a 285/75 (and not just a 70) which is what I will try next.
Old May 15, 2008 | 11:41 PM
memphis04's Avatar
So how can I recalibrate my speedometer?
Old May 15, 2008 | 11:51 PM
snoyes's Avatar
Some of the programmers, Bully Dog and Smarty, have an option to correct your speedo for different size tires. The dealership can also make the adjustment. Kinda widespread spattering as to what the dealership charges for this adjustment.
Old May 16, 2008 | 11:58 AM
welndmn's Avatar
Go to the dealer.
I had mine reflashed for the 315's for a 12 pack.
Following the other responses, 315' DO worsen your MPG. Sure it helps give you more of an over drive, but its a heavier, taller tire. Figuring all that thats why I only went down under 1 MPG.
GLHS
Feb 13, 2009 07:58 PM
zack birge
20
Jul 11, 2008 10:29 AM
slowstang232
Mar 31, 2008 08:23 AM
Kman9090
Sep 19, 2006 11:25 AM
TxDiesel007
17
Jan 17, 2006 02:54 PM
