Fuel Filter Question? Help
Old May 13, 2008 | 11:19 AM
JONNY06DIEZAL's Avatar
Okay, I think I need to change my fuel filter. It has been awhile. And Ive noticed on my commander monitor that my fuel pressure is dropping from time to time, and not at WOT. Heres the thing, I bought a fleetguard fuel filter from a dodge dealer. Well Ive had it for about a month, and get to looking at it and the part number etc. and it is the 10 micron filter and not the 7 micron. I know that cummins recommends the 7 for the common rail. Would it hurt my truck to run this filter? Will there even really be any difference? PLease help
Oh, by the way, I know along time ago there used to be a real nice HOW TO post on changing the fuel filter, and I cant find it anywhere. Any help would be great, thanks guys.
Old May 13, 2008 | 11:48 AM
Roperteacher's Avatar
The fleetguard 7 micron is the one you need. There is also a 5 micron Baldwin you can get for the stock canister. Bosch ( Who makes your injectors) actually recommends 3 MICRONS! I run the 5 micron Baldwin in the stock canister and a 2 micron kit from Glacier Diesel.
Old May 13, 2008 | 11:55 AM
Well then how many microns are the Mopar fuel filters they sell at the dealers?
Old May 13, 2008 | 11:58 AM
chipmonk's Avatar
use the 7 micron fleetguard or 5 micron baldwin. if the dealer is not out of your way, see if he'll swap out your filter for one of the new 7 micron ones.
Old May 13, 2008 | 11:59 AM
TonyB's Avatar
The 10u filter probably won't hurt anything.
How to:
Wipe / blow dirt from around filter assy
Drain fuel canister, using the water drain
Using a large socket (1" or 1-1/16" IIRC), Remove the filter lid/filter assy.
Unsnap filter from lid
Remove old o-ring
Using some diesel or fuel treatment, lube new o-ring and install on filter lid
Snap new filter to lid
Install new filter/lid assy
Cycle key-on, key-off 2-3x to prime the fuel filter.
Start truck
Old May 13, 2008 | 01:07 PM
rockcrawler304's Avatar
Wasn't there a TSB on the 10u filter? If so, I would think the dealer can only sell the 7u filter for the designated years of the TSB. But I have been wrong before.
Old May 13, 2008 | 01:12 PM
Blueboy's Avatar
Baldwin # PF7977 Drop in 5 micron.
Old May 13, 2008 | 01:30 PM
Well I took the fleetguard back, went to oriellys and got a wix, doesnt say how many micron or anything. But thats what Im going with. I dont know where yall come from but around here the dealers don't know jack shyt. I think I know more about these trucks than they do, and I know nothing.
Old May 13, 2008 | 01:33 PM
Go to www.genosgarage.com and buy them online. Get all your filters from them you will ever need. They do not carry the baldwin however.
Old May 13, 2008 | 02:16 PM
DBLR's Avatar
The Wix 33585XE is nominal at 7 microns. Wix 33585 is nominal at 10 microns. Like the others have said use either the Baldwin PF7977 or a Fleetguard FS19856 Stratapore filter and not the Mopar 10 micron filter. BTW nominal is only a 50% efficiency rating where Absolute is 98.7% efficiency. The Baldwin filter is Absolute at 5 microns and the Fleetguard is Absolute at 7 microns.
Old May 13, 2008 | 03:16 PM
radshooter's Avatar
So does the Baldwin 5 micron filter put added stress on the stock LP? I would like the filtration (would really like a 2 micron filter), but don't want to prematurely wear out the CP3.
Old May 13, 2008 | 07:40 PM
chipmonk's Avatar
i don't understand, you took the 10 micron fleetguard back to the dealer, then bought a 10 micron wix??? (both filters don't meet minimum OEM specs). if you were going to use a 10 micron filter (which you shouldn't be), you should have at least stuck with the fleetguard, as it does a good job of keeping water from getting through- do you know if the wix is a water separator, as well as a fuel filter?
Old May 13, 2008 | 08:12 PM
D45's Avatar
D45
X2.............
Old May 13, 2008 | 09:36 PM
No worries on Puttin ghe 5 micron in and restriction. I do have the GDP big line kit but fuel pressure is the same with the 5 and 7 micron
Old May 14, 2008 | 11:02 AM
DBLR's Avatar
FYI, the Baldwin filter is nominal at 2 microns and absolute at 5 microns.
chipmonk,
I have yet to get any answer when I ask if the a Wix filter is also good at stripping water out of diesel.
