Will any press/clamp work for balljoints?
I got my balljoints and tool in mail from rockauto.com . the tool turned out to only be the cups,sleeves dyes to press out the ball joints and install new ones. it didnt come with the vice clamp/press tool. My ? is do i need a actual tool or would any press work?im actually ****** off that when u order from rockauto.com they show you what tool u need according to what parts u order yet it didnt tell me anything about what i was getting. i assumed it was everything to do the job.
Go to advance auto, they will loan you a ball joint kit for $150 deposit. You get it back when you return the kit. The hardest part of the job is removing the hub/bearing. You might want to call your local napa and see if they have one in stock before you start. If your not careful you can separate the bearing and break it especially if you use a puller. If your using a puller put some tension on the puller then back off the four bolts that hold the hub about 1/2" and give them a good smack. The hub sould break free. Napa Hub assembly/bearing- BR930502- I paid $161.87 pr
Although you might not need it, make sure you atleast find a hub assembly you can go buy if yours breaks or is bad when you get it off. Napa is usually 2 days away on these. Most dodge dealers stock one or two but you'll probably have to see you bank about a loan before purchacing one.
There are quite a few threads that discuss the power steering method that works good on the hubs. Just find a steel bar, rod, bolt etc that fits between the axle and the bolt heads and press them out. May take 2 people but works great. I didn't have to start the truck, just bounced the steering wheel.
x2 on the anti-seize!
Cya
Cya
Cya
Cya
sallyman1
14
Feb 10, 2008 11:24 AM
Bad Ramer Jamer
Dec 27, 2007 09:32 AM
j
May 16, 2007 08:11 PM
