When to replace Timing Belt or adjust valves
Old Jan 10, 2012 | 04:41 PM
wolf9832's Avatar
Was wondering about when the timing belt replacement interval and or any other internal maintenance I have watch out for on my 2006 cummins 5.9. Coming up to 200 000 km at this point.
Old Jan 10, 2012 | 04:54 PM
Tedonlin150's Avatar
No timing belt to worry about. I think the valve lash is checked every 150000 miles but I'm not 100% on that.
Old Jan 10, 2012 | 05:55 PM
wolf9832's Avatar
Thanks Tedonlin150. Hard to believe how little maintenance this engine requires and just keeps on lugging.
Old Jan 10, 2012 | 08:34 PM
jhenson's Avatar
Yep, 150k on valve adjustment. My first adjustment was well over the 100k mark (03 year model) and only 1 valve was slightly out of spec.
Old Jan 10, 2012 | 09:05 PM
cincydiesel's Avatar
I'm at 170,000 miles on the original lash.. I need to get this done.. Starting to sound like a 12 valve
Old Jan 11, 2012 | 01:12 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
I'm at 215K and still original lash and running like a swiss watch.... knock on wood! Belt's original too... I wonder if I should put a new Gatorback belt on there? Hmmm.
Old Jan 12, 2012 | 12:47 PM
Lost Lake's Avatar
Maintenance? You mean there's a way to get into the engine compartment to do things in there??? Is there a hidden lever somewhere to pull or something?
Old Jan 15, 2012 | 03:22 AM
papaduck's Avatar
Change the belt and keep the old one for a spare. Don't buy a new one and keep for a spare, you need to know that it will fit and was not given the wrong one, as it happened to me. Lucky I changed it at home.
My manual says to adjust the valve lash at 1115k miles. I am there but haven't done it yet.
Old Jan 15, 2012 | 08:13 AM
Asher's Avatar
What others have said... if you like turning wrenchs to fix stuff, this engine isn't for you... The only issues I have had with this engine are self inflicted by me... It got to the point that I bought a second car to wrench on because I knew that if I didn't I would be in the same boat of some of the others with dual pumps, twins, etc
Old Jan 15, 2012 | 11:58 AM
Sur5er's Avatar
I HEAR you on that one! "Wrench's" always like tinkering. If you have a good 5.9, do the oil and filters, it's like watching paint dry
Old Jan 15, 2012 | 03:06 PM
DBLR's Avatar
"My manual says to adjust the valve lash at 1115k miles."
Wow a million miles before it needs a valve adjustment!
Old Jan 15, 2012 | 05:24 PM
papaduck's Avatar
Oops!!! I hit that one 1 to many times.
Old Jan 18, 2012 | 06:09 AM
kry226's Avatar
I really don't pay too much attention to the manual in regards to the valves. I first adjusted mine at 45K and it made a world of difference in noise and seemed to run better too. This has been confirmed many times over on other trucks in the various Cummins forums. For me, I adjust valve lash every 50K.
leadfootdodge
Jan 2, 2010 01:30 PM
CTD99
Sep 17, 2005 01:00 AM
possum
Aug 16, 2005 01:36 AM
George Jungle
Mar 9, 2005 06:53 PM
Xplorer
Jul 30, 2004 05:03 PM
