engine break-in / adjust valves?
Old Sep 16, 2005 | 04:49 PM
CTD99's Avatar
I've got 350 miles on it so far, 150 more miles of minimal idling for the cam break-in... anything special I should do for general engine break-in? One cylinder is new (sleeve & piston), the rest of the pistons got new rings, and all the bearings are new.
Should I just drive normally?... drive it easy?... or drive it like I stole it? I haven't pushed it too much so far but I've also heard in the past that it's good to work these engines hard during break-in, even hooking up a trailer. How long (if at all) should I wait before I tow?
Also, do the valves need to be checked during, or after break-in? Or can I just go with the normal service schedule?
Thanks.
~ Russ
Old Sep 16, 2005 | 06:00 PM
J BODY's Avatar
Personally I would let it cool overnight and run the valves.
Old Sep 16, 2005 | 06:32 PM
CTD99's Avatar
Just to clarify... you're saying I should check the valves now, at my current mileage?
Old Sep 16, 2005 | 06:34 PM
Marine's Avatar
Veteran: Marine Corp
Did you specifically ask them what they set the lash at?
Old Sep 16, 2005 | 06:39 PM
CTD99's Avatar
Off the top of my head, I set it a little on the tight side (from standard .01/.20) intake to .08 and exhaust to .18.
Old Sep 16, 2005 | 06:42 PM
Marine's Avatar
I think I would definitely do them. I would loosen them up, and do them right at spec.
Old Sep 16, 2005 | 06:54 PM
CTD99's Avatar
I thought these engines liked tighter valves though?...
Old Sep 16, 2005 | 07:17 PM
Marine's Avatar
Look at the spread that they allow for the intake and exhaust. There is a tight window there. The spec on the tight side is there for a reason. Why make it tighter?
Old Sep 16, 2005 | 08:30 PM
Huff nPuff's Avatar
Drive normally, on the gentle side, until your next oil change.
Change the oil a little early,if you have head studs,retorque the heads then readjust valves.Just my 2 cents worth.
Old Sep 17, 2005 | 01:00 AM
Smkndzl's Avatar
Drive it like you normally do, we do an average of 5 overhaul a week and we fire them up , quick check for leaks , never let them sit there and idle for more than 5 mins. after an overhaul, then put them right on the dyno and run them for an hour at full power and varying the rpm every 5 to 10 mins. as for doing the valve adjust again , waste of time..... some guys like to change the oil again but that is for thier own satisfaction.
leadfootdodge
Jan 2, 2010 01:30 PM
wadecool
Apr 1, 2007 09:34 AM
possum
Aug 16, 2005 01:36 AM
George Jungle
Mar 9, 2005 06:53 PM
Xplorer
Jul 30, 2004 05:03 PM
