What's the torque specs for the fuel filter housing cap? Giving me a hard time.
Old Nov 1, 2009 | 10:29 AM
Rednecktastic's Avatar
Last couple of times I've changed the fuel filter I have been having a hard time getting it to crank. This time I wanna do it perfectly no guess work.
Thanks in Advance!
Old Nov 1, 2009 | 10:34 AM
Spooler's Avatar
Just snugg the cap on, it's plastic, and make sure you use the new rubber seal for the cap, dash some diesel on it to oil it up. As far as having a hard time cranking it. Cycle on and off three or 4 times to purge the air out of the system and fire it up.
Old Nov 1, 2009 | 10:49 AM
It use to crank after 3-4 cycles. Now I have to do that, then spin it a few times, then cycle it a few more times, then spin it over some and hope it will crank.
Anyone else have this problem?
Old Nov 1, 2009 | 11:38 AM
brianhanna's Avatar
Torque spec is 25 ft/lbs. I've only ever had to bump the starter once and let the pump run until it stops. Then it fires right up.
Old Nov 1, 2009 | 01:51 PM
D-Roc's Avatar
No german torque for me...as one of the previous posters added, just snugged up is fine.
Old Nov 1, 2009 | 02:00 PM
Lost Lake's Avatar
I just screw it on by hand, then make it pretty tight with a wrench.
You have one of those new filters? My '06 is just the lid that the filter snaps onto.
Old Nov 1, 2009 | 02:04 PM
Yeah mine is an 07 5.9 which should use the same filter as you guys, 7 micron fleet gaurd. I decided to go ahead and wait till tomorrow to do it and just change my oil today... Reason being is my oil is out at my place in the country and I'll be there by myself.
I'm worried it won't crank back up this go around because the last couple times it has been giving me heck.
Maybe I have a weak lift pump????
Old Nov 1, 2009 | 02:06 PM
Lost Lake's Avatar
It must be the 6.7's that have the different filter.
I just bump the engine and let it sit and fill up too. I suppose you could leave the cap off and see how fast it fills when you turn the key on.... Two person job of course!!
Old Nov 1, 2009 | 04:51 PM
NickBeek's Avatar
Sound like you have no lift pump to me. Mine has 116K miles on it and it fills up and starts after one bump after filter change or bowl drain.
Old Nov 1, 2009 | 07:47 PM
When you guys say bump do you mean bump the starter or just key on/key off?
Old Nov 1, 2009 | 07:54 PM
Sandhopper's Avatar
I just turn the key on three cycles with out cranking, then the fourth turn I crank it and it starts right up. I put the death grip on the filter cap but I do not use a wrench... I was warned by folks that have cracked their plastic caps that wrenches can be problematic.
Old Nov 2, 2009 | 08:14 AM
TonyB's Avatar
FYI...at least on my '06, the torque value is labeled on the cap!
Tony
lniemeyer2
Oct 24, 2012 12:11 PM
Troutstrannysvc
Mar 2, 2008 07:44 AM
sterling
Oct 19, 2007 05:32 PM
ajpulley
Jan 16, 2006 04:21 PM
