How to troubleshoot a CP3
Old Sep 30, 2009 | 01:31 PM
kevinmwoods's Avatar
Is there a good thread or article on troubleshooting a CP3 anywhere????
Thanks....
Old Sep 30, 2009 | 02:42 PM
Erik@LCD's Avatar
What's going on with yours or what issue are you having that you think its the CP3?
Old Sep 30, 2009 | 03:20 PM
If I accelerate real hard or if I put a load on the truck it acts like it runs out of fuel. I let off the accelerator and ease back into it and it runs fine then. If I just drive the truck around normal with no load it runs fine. I've already replaced the lift pump and problem is still there.
Old Sep 30, 2009 | 04:26 PM
Erik@LCD's Avatar
Are you running a programmer? even a fresh lift pump won't keep up with a decent tuner. How fresh is the fuel filter? I would get a gauge on there and see what the FP is and also hook up a scanner and look at rail pressure.
Old Sep 30, 2009 | 08:42 PM
annabelle's Avatar
Mine did the same with a stock LP......try an after market LP. Roll into the accelerator for now.
Old Sep 30, 2009 | 09:38 PM
no_6_oh_no's Avatar
Rail pressure gauge and LP pressure gauage to start with. That will give you an idea where to start and whats causing the issue.
Old Sep 30, 2009 | 09:53 PM
Texan1983's Avatar
x2 gauges will tell you whats going on and where the problem is...
Old Oct 1, 2009 | 09:58 AM
Thanks for the replys... I will be adding gauges soon... here is a little more information.. My truck is bone stock as far as the powertrain goes.... the only mod that I have made is the new LP and it is a FASS 95/95-1008.... Same problem before and after the install of the FASS.... Are there any sponsors on here that sale gauges? thanks again...
Old Oct 1, 2009 | 10:17 AM
Erik@LCD's Avatar
ok, so we can probably rule out the LP. I would lean towards the relief valve or the FCA at this point
Old Oct 1, 2009 | 10:45 AM
CamperAndy's Avatar
Or the rail relief valve.
Old Oct 1, 2009 | 10:51 AM
Erik@LCD's Avatar
That's what I said?
So I guess my next step is to get gauges to diagnose the problem...
What do yall recommend on gauges...???? Install a permanent LP gauge and use a programmer to check RP????? or what???
Eric do yall sale gauges? and what setup do you recommend??
Old Oct 1, 2009 | 01:02 PM
I found this in my Service Manual.....
checking FCA...
"After removal, inspect FCA for corrosion or
damage. Shake the FCA and listen for a rattle. If
FCA does not rattle, replace it."
What else can I do to trouble shoot the FCA?
Can I check the resistance of it or anything else?
Is there anyway to troubleshoot the relief valve other than monitoring fuel pressure?
Old Oct 1, 2009 | 02:06 PM
CamperAndy's Avatar
That's what I said?
So you did, my bad, must be the dyslexia kicking in and making miss words.
Old Oct 1, 2009 | 02:36 PM
Erik@LCD's Avatar
No worries man!
