Whats a good fuel filter to run in stock housing?
Old Oct 6, 2008 | 07:24 PM
sallyman1's Avatar
i normally run the wix 10 micron filter i believe. hats all my part store had. where can i get a 5 or 7 micron filter/water seperator? post and part numbers if so. id like fleetguard, baldwin #s etc..
Old Oct 6, 2008 | 07:32 PM
coblanchard's Avatar
Can't remember the numbers offhand, but you can get the fleetgaurd and baldwin #'s from their websites.
found em
FleetGuard FS19856
Baldwin PF7977
Old Oct 6, 2008 | 07:52 PM
53 willys's Avatar
I like the Baldwin PF7977...it's 5 micron..lowest micron rating I have seen....
Old Oct 6, 2008 | 08:11 PM
MikeyB's Avatar
Another vote for the Baldwin PF7977.
MikeyB
Old Oct 6, 2008 | 08:33 PM
D45's Avatar
D45
Same here....been using it for about a year now.
Old Oct 6, 2008 | 09:15 PM
sallyman1's Avatar
is it a water seperator as well? whats the diff between the water seperator filter or just the filter? how can u tell whats a water seperator or not?
Old Oct 6, 2008 | 09:16 PM
sallyman1's Avatar
does fleetguard or lubefiner make fuel filters for our trucks?is the pf7977 for my 2004.5 ram diesel?
Old Oct 6, 2008 | 09:19 PM
MikeyB's Avatar
The PF7977 is for our trucks. And it's also a water separator.
Fleetguard is a division of Cummins, so it's the OEM filtration system.
MikeyB
Old Oct 6, 2008 | 10:11 PM
Another vote for the baldwin, thats what I use.
Old Oct 6, 2008 | 11:23 PM
mrblond's Avatar
Try these P/N's
/Fleetguard FS19856 7micron 14.25 Genos /FS19855 10micron-14.95
/Baldwin PF7977 13.36 Dougs
Old Oct 7, 2008 | 08:29 AM
TNTech's Avatar
The FS19856 is the filter that is specified for the Dodge Ram. It is 7 microns. A seven micron filter is specified for the Dodge housing. Be careful using products that are not seven microns and that don't cross to the FS19856, you could void any warranties on the filter. Also the Fleetguard filter has a Stratapore media. They have a patent on this media so no one else has it.
Old Oct 7, 2008 | 10:01 AM
Hemi6677's Avatar
Blake gave me an "A" for effort!
Just installed my Baldwin PF7977 5-micron this weekend.
Ordered two from this link.
http://www.adiesel.com/store/itemdet...knumber=PF7977
Old Oct 8, 2008 | 09:33 AM
sallyman1's Avatar
my last filter i bought was from part source in canada and it was called ......it was in black box with red writing. i believe it was SDF or SKF or something.all i know it was identical to my old one except it went on stem harder. like the rubber grommet on the bottom made a tighter seal around filter stem
Old Oct 8, 2008 | 01:00 PM
DBLR's Avatar
The Baldwin Pf 7977 and FS19856 Fleetguard Stratapore are the only 2 fuel filters that meet Cummins Spec's for both dirt holding capacity and water separation.
Old Oct 8, 2008 | 05:35 PM
GaCamper's Avatar
The Baldwin PF7977 is for our trucks and it is also a water separator. Works find in my truck.....Check around your area for a Baldwin dealer. Buy local if you can and save on freight cost.
