Whats gone wrong with your Ram?
Old Sep 3, 2009 | 04:58 PM
  #121
limpnoodle88's Avatar
havent had my 06 too long but i have developed a vibration starting at 71-72mph and fading away at about 76-77 mph, anyone had this problem?
Old Sep 4, 2009 | 03:23 AM
  #122
Diesel Duke's Avatar
1 Problem Ram.
One drivers side power window control switch. Thats all. _______________.2003,patriot blue,LB.,3500 Ram QC.4x4,No lift,No engine mods.Exterior accessories ,Yes! 38,800 current miles.
Old Sep 8, 2009 | 04:16 PM
  #123
DBLR's Avatar
Hate to say this but my valve body is shot and being replaced under warranty with about 33,500 miles on it.
Old Sep 8, 2009 | 04:30 PM
  #124
wafflehouse's Avatar
I just had to put a passenger side battery in. thats the first actual problem that messed with the operation of the truck. Also, the tailgate dents easily when backed into mailboxes, firetrucks, trees, and RVs. (all while my wife was driving)
Old Sep 8, 2009 | 08:23 PM
  #125
Brad5502's Avatar
1st casualty was a water pump at 109K miles - 50 miles from Yuma towing my 5th wheel. Had Rig and Truck towed to Yuma and arrived at 11PM. Cold beer never tasted so good! Fixed pump the next day gotta love PEP Boys!
Old Sep 8, 2009 | 08:37 PM
  #126
Danderson's Avatar
Just developed DW. Going in tomorrow for '08.5 steering upgrade,dual steering stabilizers and alignment. This is w/285 Toyos,not the infamous BFG 315 connection. This is dangerous stuff. Luckily I was in the right lane. Sucks. First thing wrong in 18,000 miles.
Old Sep 8, 2009 | 10:03 PM
  #127
RiverRat2's Avatar
Sorry to hear that,,,,,,bummer,,,, let us know if it fixes the problem!!!!! 18K ????that thing is practically new!!!!!
Old Sep 8, 2009 | 10:18 PM
  #128
Squidward's Avatar
Vibration a 75 mph noticed a few days after I got it, eliminated by dealer by replacing rear driveshaft. Original batteries replaced April '09 after five brutal Phoenix summers, fuel pump replaced June '09. Other than that, no problems for 90000 miles, just normal maintenance.
Old Sep 9, 2009 | 02:42 PM
  #129
FishingFather's Avatar
Fuel pump at 65,000 covered under warrantee. Today left front bearing/bushing at 130,000 ($500). No other issues, just routine oil and filters.
Old Sep 9, 2009 | 04:58 PM
  #130
staarma's Avatar
Just about to turn 50k on my 04.5 bought in August of 04. Only problem has been the driver rear door wiring harness needed to be fixed. PW and PL became inoperative found that the wire harness as it leaves the body heading into the door frayed the wires. That's it........... except I found the stock power to be insufficient so I had to fix that too.
Old Sep 20, 2009 | 01:32 PM
  #131
Dangousity's Avatar
Love the cummins, hate the rest of the dodge. The cab roof is white (CC failure), lift pump IP went out around 60k miles, Ball joints went bad, radiator hose problem, tailgate scratches o so easily as someone else mentioned, and front of the bed bends to easily from a ATV hauling, Dash seems to be coming apart, got the underneath dash flakes flowing from the air vents, drivers door open support is in need of replacement.
I will never buy another dodge, next time I will buy a Cummins and put it in something other then Dodge.
Just hit 84 k miles
Old Sep 20, 2009 | 01:45 PM
  #132
BibBubba's Avatar
just started to develop a squeeky noise up by the belt and some weird but normal transmission symtoms (shutter when i start and wierd shifting) .
Old Sep 20, 2009 | 03:57 PM
  #133
Mocho's Avatar
80k miles here now, need front axle shaft U-joints and a clutch. Maybe more. Truck is starting to beat me down with stuff Hopefully this is it for a while, although I bought it at 55k miles 2 years ago and this is really the first of repairs.
Old Sep 20, 2009 | 04:27 PM
  #134
mtnman006's Avatar
Ac
Air conditioner had been repaired 3 times...Finally, my sister had my truck for a day last month, wrecked it and a $10,100 repair job later including a complete AC replacemant...it works great now!!
Old Sep 21, 2009 | 06:21 AM
  #135
eastern shore's Avatar
155,000 leaking injector.
152,000 new tires
150,000 replaced both hubs and ujoints new ball joints and tie rods @ , the drivers side axel ujoint was bad.
Water pump 120,000.
Lift pump 115,000
drive shaft ujoints and carrier bearing 105,000
78,000 new tires
20,000 passenger side rotor and brake caliper replaced warranty
