Whats gone wrong with your Ram?
Here is the list of problems I have had with my 2004 2500 at 115,000 miles.
Power sterring pump leaks (twice), Transmission solenoid, Ball joints, radiator hose, transfer case output shaft leak (twice), water pump, front brakes,and air filter minder fell apart.
The truck has meticulously maintained and serviced. Seems like a lot of mechanical stuff has gone wrong. The Cummins has been foolproof. Wonder how the other brands hold up.
My 2004 with 50,000 miles has had three rear pinion seals and a new yolk assembly, one front pinion seal, a new turbo (it was leaking where the intake and exhaust housings come together), a new CP3 pump (it too began leaking when it turned cold,) and a left front axle joint. The cummins has been rock solid, it's just little things throughout the truck that has plagued me.
I guess I have been lucky. I got a 04 dually 4door auto with over 100k and only problem was a bad injector that was replaced under 30k miles. It shifts kinda hard but it has done that since we bought it.
DM01
DM01
I put on new ball joints, replaced the front wheel bearings, and replaced 2 u-joints.
I drive a lot of gravel and haul heavy loads. Plus enter a few sled pulls.I am sure the 22.5's speeded up wear a little to. I am just about ready to turn over 60K
I have 3 friends with 08 6.4 powerstrokes 2 of them blew engines around 25K. The third only has 8K or so. All 3 are 100% stock
Im at 125k miles and have changed the lift pump, full transmission (probably my fault), pitman arm joint, and i need to install new ball joints. Like iv always said, i bought a Cummins and got a dodge with it......
Ball joints,wheel bearings, 3 u joints, 2 lift pumps, 1 power steering pump, 3 power steering caps, track bar, APPS, TIPM, water pump,All of this was under a 100,000 miles
Then the usual brakes,tires,shocks. Like Sasqoutch I bought a Cummins and got a dodge with it.
lost my first motor at 18k on my stock 06. dropped a valve for no reason. dodge installed a "remanufactured" engine
this one seems ok so far. Im at 28k now with no other problems.
my wifes 04.5 has had a battery tray sensor and a fuel pressure sensor go bad. 30k on it with no other issues.
this one seems ok so far. Im at 28k now with no other problems. my wifes 04.5 has had a battery tray sensor and a fuel pressure sensor go bad. 30k on it with no other issues.
From: In Oroville, Ca., same house for past 46 yrs!
had to buy new tires at 110,000. Then three lift pumps under warranty. Nothin else... been really good to me, but I haven't changed much in the hot-rod dept. so I expect it to be trouble free.
