What's failing me?? U-joints?
When I'm pulling out of a parking lot or anyplace that requires me to turn the wheel a considerable amount, I get a feeling in the steering wheel similar to when the truck is in 4WD and you turn on hard pavement.
Anybody experience this and if so what was the fix?
Thanks
John
Thanks
John
Guest
Posts: n/a
Sounds like front axle u-joints. Jack up the front end and rotate the tires by hand with the steering wheel straight. Then turn the wheel and rotate the tires. If the joints are bad they will turn much harder when the steering wheel is not straight.
I have the exact year , model as your truck, symptoms were the same, it was the front U joints, they replaced them under the power train warranty for 100 dollars deductible.
Next if not already will be the driveshaft universal joints. Those were also under warranty.
I had all three replaced at one time, now I am waiting for the little electric fuel lift pump to fail, the one mounted on the fuel filter. I have 68,000 miles on the truck so I hope it last a bit longer.
The lift fuel pump is under the engine warranty.
Then your ball joints, mine are starting to get a bit of play in them at 68,000 miles.
Still they are very nice trucks ...
The problem with having the joints replaced under warranty is they'll replace them with the same junk joints. Then a few years later you'll pay to replace them again. Replace them with some good greasable joints and be done with it.
yes you have to remove the hubs, but snapon makes a tool for like 40 bucks that pushes the hub out from the four bolts that hold it on, its supposed to not damage the hub, i bought one now im just waiting for the binding sensation in the steering wheel.
Does anyone have a part number for a good set of greasable joints. 04.5 4WD.
Thanks
John
If you do the socket and power steering method their not that bad. My passenger side popped right off first try. the drivers side took a little more work but I replaced both of them in about an hr. (85k miles)
LJRoy
16
Sep 23, 2006 07:52 PM
Gear Poet
Jul 25, 2005 08:39 PM
Asher
Jul 19, 2005 01:36 PM
swansong04
14
Jun 11, 2005 12:02 AM
