What is Timing?
Old Apr 23, 2009 | 08:48 PM
.boB's Avatar
What is Timing?
Exactly. I understand timing on a gas engine - probably better than most.
But what is timing on a diesel? Is that the fuel injection pulse in relation to the piston?
How does changing the timing change performance?
Old Apr 23, 2009 | 09:23 PM
1985cucv's Avatar
timing is when the fuel gets injected into the cylinder. from what i understand too much timing can cause a hot spot on the piston causing it to melt because the fuel is hitting the piston to early and it is staying to hot. that is how my buddy from peteerbilt explained it to me
Old Apr 24, 2009 | 04:18 AM
Dodgezilla's Avatar
Yes.
Timing refers to at what point in the stroke that the fuel is injected. "Too much timing" would refer to having it inject the fuel too soon in the stroke...
Duration refers to how long the injectors stay open on each stroke.
Pressure refers to increasing the fuel pressure at the injectors so that when they open they have no choice but to spray more fuel.
That's how I understand it anyways......
Old Apr 25, 2009 | 06:34 AM
Jeff in TD's Avatar
As I understand it, advancing timing can produce an increase in MPG, but if you put a heavy load on the engine or advance the timing too much, it can cause major engine damage.
Old Apr 26, 2009 | 12:19 AM
.boB's Avatar
That's exactly the way it is with a gas engine, for completly differant reasons (I think). I wonder why it works that way with diesel?
Old Apr 26, 2009 | 06:25 AM
m21221's Avatar
Is there anyway to check it, manually or electronically?
Old Apr 26, 2009 | 09:16 AM
1985cucv's Avatar
the older trucks you can check it manually like on the p pumped or ve motors but i belive andthing newer than 98.5 is all electronic as the pumps are electronic.
GR40RCapri
Jul 24, 2006 11:47 PM
GR40RCapri
Jun 25, 2006 12:53 AM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
redhornet
May 28, 2004 06:06 PM
