What oil do you run?
Old Nov 28, 2010 | 09:03 PM
justin mcfall's Avatar
Keep us posted on the analysis bro...
Old Nov 28, 2010 | 09:04 PM
CLS LLC's Avatar
15w 40 valvoline premium blue ONLY
Old Nov 28, 2010 | 09:17 PM
NavyDood's Avatar
Originally Posted by worldindustries
amsoil 5w-40 diesel oil
Originally Posted by Dieseljunkie
I run Amsoil 15w40 HD diesel and Marine, and in the winter, we get down to about 14* F in the winter. Never had an issue.
Scott
Amsoil AME 15w-40 Diesel & Marine is better IMO. Higher TBN and CI+4 rating which is all you need for a 5.9. Good for -44 F too.
Old Nov 28, 2010 | 10:48 PM
redneck yankee's Avatar
Rotella 5W-40 all year around and change every 5K miles
Old Nov 28, 2010 | 11:19 PM
jim.the.anvil's Avatar
I'm gonna run the rotella 15-40 for now. I'll switch to synthetic when I change it in the springtime. I'll be able to afford it then. Gonna run with Mobile 1 synthetic when I make the change.
Old Nov 29, 2010 | 09:38 PM
GraveDigger1's Avatar
Originally Posted by surfram
Mobile Delvac 15-40. No Rotella smell, usually on sale for $9/gallon, and easy pour spout built into the cap.
this
Old Nov 30, 2010 | 08:50 AM
HL649's Avatar
I run Co-op DMO 0W-40 synthetic year round in everything. It is an excellent quality oil, easy to get locally, and it's cheap. I've got nearly 400k (the last 300k on the DMO) on my 95 with this oil and it purrs. The '06, bobcat, and tractor has had nothing but DMO since new.
Old Nov 30, 2010 | 09:35 PM
gadget.35-06's Avatar
Between both of my Cummins I have over 700,000 miles on Delo 15w40. I see no reason to change. Rotella and Delvac gave me lower oil presure readings in the 91 so I have not used either in the 06.
Old Nov 30, 2010 | 09:41 PM
1-2-3's Avatar
Just a plain ole guy
Delo 15w40 here too. Never an issue for me. My FIL ran it in his CTD hot shot rig and put several hundred thousand miles on it. He did eat many 5th gear nuts, then had someone good build him a 5 speed that wouldn't break. Then after getting towed home from the first outing after the new trans, he had to get the same guy to build a rear end that would hold the new 5 speed and CTD combo. Other than that, it was a perfect truck.
Old Dec 2, 2010 | 09:56 AM
rufushusky's Avatar
I have run everything from Rotella, VPB, John Deere, Amsoil...you name it I have pretty much run it. Currently I have Castrol Hypuron in it. Good to -42*, synthetic blend and priced between dino and most synthetics...good compromise to me.
Old Dec 2, 2010 | 07:05 PM
wiskeyVI's Avatar
I was running MOBIL Delo 400 with good results, but have not been able to find it in WW the last two changes so I switched to DELO 1300.
I also switched to BOSCH filters as the stores around here stopped carring the Mobil ! filters for the truck.
I just sent in an oil sample to BS with 9000+ miles and got the best report ever back from them at just over 100k on the engine.
They suggested going to 11k this time.
I do run an OilGuard filter as well.
Winter time I add a QT of Rotella 5w-40 syn to get her flowing a bit better.
Old Dec 3, 2010 | 11:56 PM
Thundercraft's Avatar
Yep, I agree... besides... if it ever got that cold here I would Not be going out for a drive.
Old Dec 4, 2010 | 07:27 AM
newtonhubcap's Avatar
Maybe you know this but I would not run synthetic until you have seated the rings well (25,000 miles). As for running oil, I run Rotella Synthetic 5-40w. Oil analysis from Blackstone labs are very positive on the TBN rating around 10,000 mile intervals for my truck. Oil is really a personal choice.
Old Dec 4, 2010 | 07:29 AM
Rob's Red Ram's Avatar
Mobil 1 Turbo Diesel Truck 5w40 fleetguard stratapore filter.5000 mile changes
Old Dec 4, 2010 | 07:39 AM
Asher's Avatar
Delvac with fleetguard filters every 5K, unless I want that "swamp monster lives in my back seat smell" then I will run Rotela for a cycle...
