What grade oil....15/40...10/30...?
Old May 14, 2006 | 11:50 AM
LanceK's Avatar
I'll be taking delivery of a new CTD in a couple weeks.
I've seen all the chat about what brand of oil.
But what grade should I choose?
I live in the Northeast near the ocean. I would say the weather is less extreme than say in upstate N.Y.
However we do get week or two periods where the weather is 20 degrees during the day and 0 at night.
Summer is typical hot and humid.
I was thinking 10/30 in winter and 15/40 in summer.
It this a reasonable plan or overkill?
TIA
Old May 14, 2006 | 12:02 PM
If you can use the block heater during those cold snaps, the 15W-40 will be fine.
A 5W-40 (best bang for the buck is Rotella Synthetic) would be better in winter. Once the engine reaches operating temp the 10W-30 is going to be thinner than you need.
The only 10W-30 I know of that's diesel rated is Rotella T 10W-30, and that's very hard to find. I've only seen it once.
Old May 14, 2006 | 12:07 PM
Hemi Dart's Avatar
Wink
Definately see what the owners manual recommends before making a decision.
Old May 14, 2006 | 12:42 PM
TPilaske's Avatar
I run 15W-40 year round... Michigan get's it's share of cold too!
Tony
Old May 14, 2006 | 01:14 PM
LanceK's Avatar
I did order the block heater (not a standard option ) so plugging in should be common.
I'll probably plan on 15/40 for most times.
Will check the owner's manual too of course.
Old May 14, 2006 | 02:32 PM
IA_James's Avatar
I'd say 10/30 would probably be overkill if you only get down to 0 a couple times a year. If you plug it in overnight at those temps, you'll be fine. 20 degrees isn't even worth worrying about.
Old May 14, 2006 | 05:25 PM
NoChrome's Avatar
block heater is standard, just need the harness to make it work.
Old May 14, 2006 | 11:49 PM
Jreif80's Avatar
I've only had my 06 for a few weeks but my old 12 valve would start unpluged in -15 weather
Old May 15, 2006 | 09:50 AM
LanceK's Avatar
I had to choose the block heater as an option when I specd out my truck it was $10.
I just built a CTD Laramie on the Dodge site and it now lists the block heater as a $90 option...
From what I can see it is only an option. Not sure about the price difference.
Is it the option for the cord?
Old May 15, 2006 | 09:58 AM
P.J's Avatar
P.J
Thats it!.......
Old May 15, 2006 | 11:41 AM
LanceK's Avatar
Cool...saved myself 80 bucks!
Old May 16, 2006 | 12:58 PM
nickleinonen's Avatar
first winter i had my truck, i ran 10w30, then i switched to 5w40 in spring. ran that for 10k kilometers, then switched to 0w40. run that year round now...
Old May 16, 2006 | 01:49 PM
LBZ Power's Avatar
I usually stick with the weight oil recommended in the owners manual. For my truck it's 15w-40. I have always used Chevron Delo, and change it every 5000 miles or before. Synthetics are better for extreme heat and cold starting but I can't bring myself to leave them in the engine long enough to be cost effective.
Old May 16, 2006 | 01:51 PM
Atlantic4x4's Avatar
Why run a thinner oil if DC/Cummins says otherwise? Personally I will be sticking with what they recommend in the owner's manual and that is 15W40.
Old May 16, 2006 | 02:51 PM
PEAKSTRYDE's Avatar
Another vote here!!!!!!!!!!!!!!!!!!
