What fuel filter and where is it on the CTD?
Old Mar 4, 2007 | 11:23 PM
JOE M's Avatar
Is there anything else in filters on my truck I may be missing besides Fuel,oil, tranny, and air? Thanks,Joe
Old Mar 4, 2007 | 11:35 PM
53 willys's Avatar
you should buy a factory Cummins/ram manual it would help a ton if you are going to start to do your own maintenance
look in your owners manual for the "water separator" or water in fuel drain procedure it should show you where the fuel filter is.
it's on the drivers side hanging off the engine...it has a yellow lever to drain the fuel/water.
Also you may want to use the search because I think there is a full write up on how to change your fuel filter
Old Mar 5, 2007 | 01:08 AM
3500lly's Avatar
That's it for filters. I would also be sure to keep up on changing the differential fluid if you begin to do all your own maintinance
Old Mar 6, 2007 | 09:49 AM
JOE M's Avatar
Thanks for the info.
Joe M.
Old Mar 6, 2007 | 05:21 PM
belgianmagic's Avatar
check this out !
JUST MAKE SURE YOU CLOSE THE DRAIN VALVE WHEN YOU ARE DONE DRAININGhttps://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Mar 6, 2007 | 06:53 PM
53 willys's Avatar
Originally Posted by belgianmagic
check this out !
thats the one
Old Mar 6, 2007 | 08:45 PM
JOE M's Avatar
Sweet! Where are you going the filters from?
Old Mar 6, 2007 | 08:46 PM
HorseHauler's Avatar
genosgarage.com is where i get them and seems to be one of the favorites on this site...
MikeRP
79
Nov 21, 2016 10:19 PM
xp8103
Aug 14, 2014 08:45 AM
vegashd
Jul 15, 2007 12:24 PM
roc155
23
Mar 9, 2006 06:44 AM
turbo59pwr
Jul 9, 2003 04:24 PM
