What does this engine code mean?
Old Aug 29, 2006 | 11:02 AM
WACTD's Avatar
My check engine light came on this morning. Holding the odometer button while turning the key to "run" yielded the following indications, which repeated every few seconds:
S 113
, 264
C 447
(That second one has what looks like a leading comma.)
Where can I find what these codes mean? Thanks!
Old Aug 29, 2006 | 01:10 PM
dodgezilla04's Avatar
the odometer button doesnt show engine codes.
turn the key on and off 3 times(no starting) then back to on, the odometer will give engine codes.
the odo button gives chassis stuff
Old Aug 29, 2006 | 01:25 PM
WACTD's Avatar
Oops, my mistake. I'll check it using the proper procedures and report back. Thanks for the correction!
Old Aug 29, 2006 | 01:50 PM
WACTD's Avatar
OK, I've tried every triple-combination I can think of:
* Off-to-On three times, then a fourth
* Off-to-Stop three times, then a fourth
* Off-to-Acc three times, then a fourth
* Acc-to-On three times, then a fourth
* Acc-to-Stop three times, then a fourth
...and all I ever get is mileage. Is there some minimum or maximum amount of time you're supposed to leave the key in each position? I tried varying that, too, but nothing changed.
ARRRRRGGGGHHHHH!!!!
Old Aug 29, 2006 | 02:08 PM
T398's Avatar
Ya almost had it the first time, only 3 cycles no fourth.
off-on,off-on,off-on and leave on.
This should get ya what yer looking for.
T398
Old Aug 29, 2006 | 02:09 PM
mattk50's Avatar
its on-off,on-off,on-off,on-all without starting. should say either "done" or show "p" codes.it may not work on the 06 trucks.hope this helps.
Old Aug 29, 2006 | 02:26 PM
WACTD's Avatar
I tried leaving it on a while after the third and fourth cycles but didn't see anything. Based on these comments I'll go try it again and be a bit more patient [grin]. I'll report back! Thanks!
Old Aug 29, 2006 | 02:58 PM
TurboGoat's Avatar
I had the same trouble this morning. Finally got it to work. on-off, on-off, on...gave me a code "P 0071" anybody know what this means? Im hoping its fuel filter related, I'm due for a change.
Old Aug 29, 2006 | 03:24 PM
WACTD's Avatar
Got it! Error code is also P0071, just like the other poster...
I wasn't cycling on-off fast enough. I don't like to stress stuff unnecessarily, but in this case you've got to be pretty quick on the key.
Anyway, P0071 is supposedly "Ambient Temp Sensor Performance", and the claim is that the temp sensor hasn't seen more than a three degree C change in the last 200 miles. I presume they're talking about the engine intake temperature, not the overhead temp display (which has been moving around properly).
Old Aug 29, 2006 | 03:38 PM
TurboGoat's Avatar
Yeah I found the "Ambient Temp Sensor Performance" name, but I don't know exactly which sensor that is. Is it the sensor on the intake box that I bolted to my AIRAID when I got it? Is it the one under my grill guard that is conected to the overhead temperature display? It has consitnetly been 100-105 deg here in Texas for about the last 2 weeks if that means anything...
Old Aug 29, 2006 | 03:49 PM
it is the one on your airraid.
Old Aug 29, 2006 | 04:46 PM
TurboGoat's Avatar
Thanks everyone. Sorry WACTD, didn't mean to take over your thread. Just curious, what code did your's show?
Old Aug 29, 2006 | 10:56 PM
WACTD's Avatar
As noted below, the same one - P0071. Mine self-resolved today, the CEL went off and stayed off, so apparently the sensor reported more than a three degree C change today!
Old Aug 30, 2006 | 08:58 AM
TurboGoat's Avatar
Glad to hear it. I tried unplugging the sensor and had no luck. I realized my Airaid was dirty so I took it off, cleaned/reoiled it and also lightly wiped off the sensor. Something worked because the code went away.
beardedone
Dec 24, 2006 06:25 PM
dieselfan
Jul 28, 2006 07:25 PM
FDPOWER
Apr 13, 2006 11:45 AM
WalkerMike98
Jan 13, 2006 10:33 PM
salty mule
Mar 17, 2004 05:59 PM
