What do I got in my rear?
Old Jan 21, 2004 | 03:02 PM
ViperSBT's Avatar
Unhappy What do I got in my rear?
OK, I have searched through the forums and found tons of information for my needed rear axle fluid change. But a couple of questions that I have not been able to answer are:
1. How do I determine whether I have a 9.25, 10.5 or 11.5 rear axle?
2. How do I determine whether I have a Trac-Lok or a Trac-Rite differential?
Old Jan 21, 2004 | 03:59 PM
Peterbilt's Avatar
My guess is you have the 11.50 with 4.10s maybe 3.73s. Don't have any idea if you have an LSD.
Mine has a label inside the glove box with that information. Then, lookup the quantities in the owners's manual. Otherwise, look at the diff tags or possible decode you vin number. Do you have the configuration sheet from the window? Good luck.
Pete
Old Jan 21, 2004 | 04:05 PM
Peterbilt's Avatar
Oh, I think the LSDs are Trac-Rite all gears, no clutches. Someone will have specifics. Try doing a search.
Pete
Old Jan 21, 2004 | 04:56 PM
ViperSBT's Avatar
Lightbulb
Well the VIN didn't provide any insight, but that little sticker inside the glovebox sure did: 3.73/11.5 Anti-Spin.
With that said, does the Anti-Spin refer to the Trac-Lok or Trac-Rite?
Old Jan 21, 2004 | 05:29 PM
Original Junior's Avatar
I saw this question before. I believe the answer can be found on the American Axle website. Or, try a search on the TDR. Hope this helps some.
Old Jan 21, 2004 | 06:01 PM
LinearX's Avatar
I'm 99.8% certain that all 3500's got the 11.5 rearend regardless of engine choice (SO/HO makes no difference). The 2500's got the 11.5 rearend if they got the HO. I think the 2500's getting the 11.5 may have change to all of them getting it now based on the fact that the 600 is 50 state legal and is the only engine being offered at this point.
Somone correct me if I'm wrong.
Old Jan 21, 2004 | 08:29 PM
Jeff in TD's Avatar
Your truck will have the 11.5" American Axel.
It requires 7.62 pints of full synthetic 75W-90 gear oil that meets GL-5.
American Axel with limited slip (trac Rite) does not use an additive or friction modifier.
I put Valvoline SynPower in mine, just because it was available locally, but there are many other fine choices, and many threads with various opinions.
As long as it is 75W-90 synthetic that says it meets GL-5, you are using what DC requires for warranty.
Hope this helps.
Jeff
P.S. Hold on to something when you find out what this stuff costs...
Dale M
Mar 5, 2011 03:40 PM
bhoff1175
Jun 7, 2006 10:19 PM
Begle1
Jul 13, 2005 04:13 PM
joel
May 23, 2003 07:02 AM
crankbait
Feb 14, 2003 04:31 PM
