What different sounds does a failing ujoint make
Old Oct 14, 2007 | 03:07 AM
rogerL1961's Avatar
Please tell me of your experiences of what a failing Ujoint sounds like.....
Thanks guys!!!
Old Oct 14, 2007 | 03:41 AM
BgBlkTrk's Avatar
When my front driver-side axle u-joint failed it sounded like a rock caught in a hubcap-loud enough you could hear it clearly with the window rolled down.
Old Oct 14, 2007 | 06:35 AM
gmctd's Avatar
Rattle - clink - clunk - tink - thump - slight growl - vibration
Old Oct 14, 2007 | 08:49 AM
mikmaze's Avatar
where are you located? I'll drive by and let you listen ahhahahahaha, rattles clunks depending on which one it is, or just taps and can be heard as you drive by a concrete highway barrier, wall any thing a sound willbounce off of.
Old Oct 14, 2007 | 05:06 PM
Little03's Avatar
If you feel a vibration then I would just quickly have a gander under the truck and try and rock the drive shaft if it wiggles lots time to replace them.
Old Oct 15, 2007 | 02:04 AM
Det 1's Avatar
The u-joint immediately behind the carrier bearing on my truck was vibrating/shuddering as I left from a stop. When I checked it for movement I found it wasn't loose at all, but after driving a good distance it was warm to the touch. As I removed it I found it had lost all lubrication but hadn't lost any of the needle bearings, yet. The replacement has a grease fitting on it.
CoolumConst
Jul 28, 2007 06:18 PM
Ron E
Jan 19, 2007 09:48 PM
Thenewguy
Aug 18, 2006 05:49 PM
BRUISER
Aug 17, 2006 12:01 PM
