Sounds different...
Old Jan 19, 2007 | 03:50 PM
Ron E's Avatar
Sounds different...
After spending some time around 3 different trucks (89,91,93 all 4x4 automatics)
I realize mine sounds a good bit different. Not the exhaust, but the combustion rattle. Mine is louder inside, or outside the truck.More metallic sounding. Don't get me wrong, it doesn't sound "bad", I like it. But it's different, and ignorance breeds paranoia. The others sound like mine would if wrapped in a blanket (if you can picture that). Can timing or some other "adjustment" cause this?
Old Jan 19, 2007 | 04:18 PM
Fred Swanson's Avatar
timing, fueling will make a change to sound of the motor.
Old Jan 19, 2007 | 04:43 PM
4RnrRick's Avatar
Valves out of adjustment???
Old Jan 19, 2007 | 05:37 PM
Probably got plenty of timing. Check to see that your KSB solenoid is getting power when the engine is warm.
Old Jan 19, 2007 | 07:59 PM
rlyons's Avatar
For some strange reason my engine has more rattle when the KSB is advanced than when it cuts off?
Old Jan 19, 2007 | 09:07 PM
gman07's Avatar
Thats the way it should be. On IC trucks, the KSB is advancing the timing when it has power. On the non-IC trucks, the KSB advances timing with a wax motor; it starts advanced, then when the KSB gets power, it retards the timing back again.
Old Jan 19, 2007 | 09:48 PM
Ron E's Avatar
Gotcha. Thanks. I'll check it out.
onebadgoat
Aug 26, 2007 05:29 PM
CoolumConst
Jul 28, 2007 06:18 PM
Thenewguy
Aug 18, 2006 05:49 PM
BRUISER
Aug 17, 2006 12:01 PM
