What did I do and What does it mean?
Old Jan 30, 2008 | 05:28 PM
Chessbay's Avatar
This evening when I got home from work I decided I would check the hours on my truck just to see what they were. Well I could not remember the exact sequence so I guessed.
Anyway, I turned the key one click forward (whatever that is). Then I pressed the trip/odometer thing on the dash and then turned the key to the on postion. All of a sudden a series of events happened that I have never seen before.
The guages all began to move in some kind of sequence and a series of numbers was displayed in the odometer.
The numbers had some symbol or something in front of them, they are as follows: (5 37),(= 323), (C 542). Then the hours would show up at the end of the sequence @ 407hrs.
The equals (=) symbol and the letter C were the closest things I could find to represent what was shown on the dash.
Any ideas as to what I did and what all this stuff means. Obviously, I am new to diesel trucks so I don't have a clue.
Old Jan 31, 2008 | 06:40 AM
Chessbay's Avatar
Surely someone must know.
Anyone?
Old Jan 31, 2008 | 06:44 AM
spitfire9137's Avatar
I believe all you did was run a test cycle on the dash.
Old Jan 31, 2008 | 07:01 AM
MikeyB's Avatar
Yep, diagnostic mode for the instrument panel.
MikeyB
Old Jan 31, 2008 | 07:33 AM
jkitterman's Avatar
Don't be messing around unless you know what you are doing. The truck may put you on double, secret probation
Old Jan 31, 2008 | 01:54 PM
billie's Avatar
Wait til you find the automatic butt wipe feature by accident...that should give you a surprise .
Cya
Old Feb 2, 2008 | 12:16 AM
06trx's Avatar
That is how to check for chassis codes also. C-_ _ _ _ . To check for power train codes you cycle the key 3 times to get the P-_ _ _ _ .
Old Feb 2, 2008 | 07:56 AM
Chessbay's Avatar
I'll bite.
What's a chassis code and how do I look them up?
Old Feb 2, 2008 | 10:07 AM
scootertrash35's Avatar
the normal hour check is key on and hold trip button for 5 seconds
Old Feb 2, 2008 | 10:18 PM
06trx's Avatar
Automotive-Usenet.com » Dodge » alt.autos.dodge.trucks
> 67 81 one second pause
The cluster codes are of the format 'xx yy', meaning code 'xx' occurred 'yy'
key cycles ago. In your particular case, code 67 means "All door unlock
output circuit shorted to ground or voltage." If you're interested, here's
a complete list:
01 Airbag warning indicator output circuit shorted.
02 Airbag warning indicator output circuit open.
03 ABS indicator output circuit shorted.
04 ABS indicator output circuit open.
05 MIL indicator output circuit shorted.
06 MIL indicator output circuit open.
07 Wait to start indicator circuit shorted.
08 Wait to start indicator circuit open.
0B BTSI output circuit shorted or open.
22 Headlamp switch input circuit shorted.
23 Headlamp switch input circuit open.
24 Turn hazard switch input circuit shorted.
25 Turn hazard swiitch inpot circuit open.
27 Courtesy/dome output circuit shorted or open.
28 Glovebox/map lamp output circuit shorted or open.
29 Cargo lamp output circuit shorted or open.
40 Wiper switch input circuit shorted.
41 Wiper switch input circuit open.
42 Wash/beam input circuit shorted.
60 Passenger door lock switch input circuit shorted.
61 Passenger door lock switch input circuit open.
62 Passenger door lock switch input circuit stuck.
63 Driver door lock switch input circuit shorted.
64 Driver door lock switch input circuit open.
65 Driver door lock switch input circuit stuck.
66 All door lock output circuit shorted to ground or voltage.
67 All door unlock output circuit shorted to ground or voltage.
68 Driver door unlock output circuit shorted to ground or voltage.
6C Driver cylinder lock switch input circuit shorted.
6E Driver cylinder lock switch input circuit stuck.
80 Incorrect odometer value found.
81 Remote radio switch input circuit high.
82 Remote radio switch stuck.
A0 Internal module FLASH memory checksum failure.
A1 Internal module bootloader failure.
A3 Battery voltage open.
A5 TCCM messages not received.
A7 VIN checksum error.
A8 VIN previously stored.
A9 PCI bus internal failure.
AA PCM messages not received.
AB TCM messages not received.
AC ABS messages not received.
AD FCM messages not received.
AE ACM messages not received.
AF SKIM messages not received.
B0 RKE fob batteries low.
B1 RKE module communication link.
00 Done All Diagnostic Trouble Codes (DTC) have been displayed.
Note that these codes only refer to functions controlled by the instrument
cluster (which is quite a bit in the 3rd gen Rams... the instrument cluster
incorporates the airbag system, central timer system, keyless entry system,
etc.)
For engine/powertrain diagnostic information, as another poster mentioned,
cycle the ignition key from OFF-ON-OFF-ON-OFF-ON. Your odometer will
display any stored OBD-II codes, ending with 'pDone'.
(Autozone, or any other 'free codes read' place, will only read the OBD-II
codes, not the cluster codes)
Tom Lawrence
#7 (permalink) 07-08-2006, 02:30 PM
Tom Lawrence Posts: n/a
Re: 2005 Dodge Computer Codes
a complete list:
etc.)
Members | Search
Machinos
Nov 8, 2007 03:38 PM
RLS
Feb 11, 2003 09:53 PM
Jones0027
16
Jan 31, 2003 01:17 PM
1ST GEN.
Jan 12, 2003 10:33 AM
nevrenufhp
14
Nov 27, 2002 09:55 PM
