What could cause vibration at 1800 rpm?highway
Old Feb 2, 2009 | 01:48 PM
sallyman1's Avatar
i have a 2004.5 dodge ram. i had a vibration that seemed like driveline at 1800-2000 rpm or 100 km/hour. slight vibration but BAD vibration under load.so bad my gps suction cup lets go on windshield. I have had all ujoints checked (1 replaced), tires balanced, transfer case checked and just stuck $4000 into tranny. Could it be injector/cp3/FCA related? i had goerend triple disc torque installed, shift kit and upgraded valve body and new clutch packs in tranny. engine mounts seem ok. what else? no codes either???
Old Feb 2, 2009 | 01:57 PM
Spooler's Avatar
Have you checked your carrier bearing?
Old Feb 2, 2009 | 01:58 PM
sallyman1's Avatar
thats the thing. i dont have one. do only long boxes have 1 because i have a short box. if not where is it?
Old Feb 2, 2009 | 02:03 PM
Spooler's Avatar
You may not have one. I have a long box with the 2 piece driveshaft and I have one.
Old Feb 2, 2009 | 02:09 PM
GreyTD's Avatar
Don't know how much of PIA it will be, but you may want to get the drive shaft checked for balance. Did you get the front shaft check for wore joints also? unfortunately SWB trucks do not have a carrier bearing. seems you have covered quite a few bases already though.
just had a thought if you put it in neutral while driving (saftey first no one around) does the vibration go away.
Old Feb 2, 2009 | 02:21 PM
sallyman1's Avatar
i just found out the garage i went to installed the wrong rear axle u joint. they didnt install the greaseable precision 330A , they accidentally put in a napa one that fit way too tight yet it still fit. do u think this is the problem?
Old Feb 2, 2009 | 02:46 PM
GreyTD's Avatar
If it was a tight fit that means they could have damged the ujoint squeezing it to get the clips in. Yea it could be the problem. Are they going to replace with proper one?
Old Feb 2, 2009 | 03:11 PM
sallyman1's Avatar
yes. warranty.
Old Feb 2, 2009 | 03:14 PM
Capp35's Avatar
It just started doing this or has it always had a slight vibration?
Reason I am asking, the 2003 and 2004 models had a problem with drive shaft vibrations. Supposedly the newer trucks shaft are made from a different vendor now.
There were alot of write ups on this, back then.
Some had it and some didn't. I was one of the lucky ones.
Old Feb 2, 2009 | 03:26 PM
sallyman1's Avatar
just started doing this about 2 months ago. never ever had this. i doubt its driveshaft unless they twist in time. i dont rough ride or 4 by in ditches or fields. i actually drve like a granny. so do u think, cp3,fca or injector? it idles fine and revs up nice in park. just under load theres vibration.
Old Feb 3, 2009 | 05:00 PM
sallyman1's Avatar
any1? when i feel this vibration at 1800 rpnm on highway it goes away dramatically when i push tow/haul button.engine or ujoint?
Old Feb 4, 2009 | 08:13 AM
Capp35's Avatar
Standard or Automatic Trans?
Had a cracked flywheel on my auto Ford, that acted like this.
Old Feb 4, 2009 | 08:34 AM
sallyman1's Avatar
automatic. tranny was just removed and rebuilt. new torque also so i imagine new flexplate also so they should of saw flywheel
Old Feb 4, 2009 | 10:21 AM
Capp35's Avatar
Mine cracked 2 months after Ford replaced my tranny in my F250.
Claimed their tranny replacement had nothing to do with it....... yea right.
Old Feb 4, 2009 | 06:41 PM
cincydiesel's Avatar
Sallyman, I'm in the same boat.. I've got the weird vibration myself. Just replaced my ujoints and hub bearings. I'm starting to think its my carrier bearings however I cant tell if its good or bad??!!
