What are the correct alignment specs for a 3rd gen ?
Old Oct 28, 2008 | 07:36 AM
Valv's Avatar
I've been to dealer, got charged $ 59 for a "they are still within spec" check.
I am not happy with results, truck pulls a,little to right and steering is too light.
Front end is all new, including PSC reinforcement bracket.
Old Oct 28, 2008 | 12:54 PM
no_6_oh_no's Avatar
What are you running for tires?
Old Oct 28, 2008 | 01:30 PM
Valv's Avatar
Stock 235/70/17
Old Oct 29, 2008 | 08:47 AM
woodzy's Avatar
just air up the tire Better than having to deal with a dodge service department IMO
Have you thought about taking it to schwabbies?
Old Oct 29, 2008 | 08:49 AM
Valv's Avatar
Who's schwabbies ?
woodzy's Avatar
les schwab
Old Oct 29, 2008 | 09:19 AM
Valv's Avatar
Originally Posted by woodzy
les schwab
We don't have any nearby.
Old Oct 29, 2008 | 10:14 AM
jacob_armour's Avatar
im not sure how much it is pulling but the road crown will cause it to go to the right drive in the oppisite lane and see if it pulls to the left
Old Oct 29, 2008 | 01:01 PM
Valv's Avatar
Guys, I really appreciate the effort to help, but come on...
All I need to know if somebody has the specs for correct alignment.
Old Oct 29, 2008 | 03:22 PM
CTD NUT's Avatar
Really, the "specs" are just about useless....and the range of "in spec" is even more so on these trucks. Caster is extremely important on the front of these 4x4's yet it is just about completely overlooked. The "in spec" range is 0* - 2*.....come awn?!?! First off, 2* isn't enough and the suggested in spec range is only 0* - 2*. I run my caster at roughly 3.5* - the most I can get out of the lower control arm cams which is pathetic. I think all the dealers care about is balljoint life....hence the very limited caster. More caster = reduced bump steer and a stronger return to center action of the steering. This really helps these trucks track straight. All you have to do is drive one with 0* and then drive one with 3.5*.....there isn't really a comparison.
Since there is no simple way to effectively adjust camber (offset balljoint sleeves ), you can rule that out and just make sure the alignment shop puts the toe "in spec" and just tell them to crank up the caster as far as it will go - you might get 4* but I doubt it. It will probably be a little less. My limited experience with alignment shops is that the tech will NOT do what you ask them to do and since many of them don't really know what they are doing, will just assume you don't either at which point they will only do what the computer tells them to do which simply means they will make sure the alignment is with in the accepatable "in spec" range. If you are lucky enough to find an alignment tech that is versed in a bit of theory and is capable of rationalizing beyond what the alignment computer tells him to do, then you are good to go.....good luck with that!
Old Oct 29, 2008 | 04:37 PM
Valv's Avatar
That's EXACTLY what I wanted to hear (actually read).
Thank you CTD NUT !!
Old Oct 30, 2008 | 09:02 AM
ModManiac's Avatar
I bought the moog ball joints that have the adjustable uppers, are those bad? Can I adjust camber off them?
Old Oct 30, 2008 | 10:17 AM
foolkiller's Avatar
i set my castor full forward and my tow-in as close to even while erring on the side of towed-in. i usually end up with 1/16th or less tow-in or keep trying until i do. i like 1/32nd. can take a few trys before i get it where i want it. if i hit 1/16th and the truck steers nice.... i'll let it ride. i like less though for tire wear and fuel mileage.
anything more than 1/16th and i start to notice funky tire wear. with my tires anyway.
j
Valv
Oct 17, 2008 02:46 PM
IdleChatter'n
Jun 5, 2006 04:55 PM
04ctd
Jun 14, 2005 06:16 PM
chsaverline
Jun 10, 2004 10:31 AM
Holycack
Sep 17, 2003 01:24 PM
