What brand ATF+4 & how much???
Old Mar 18, 2011 | 09:33 AM
MikeMotorhead's Avatar
I am about to change my ATF in my 05 CTD automatic and my owners manual does not say how much the capacity is. Also they only recomend Mopar ATF+4 fluid. Can I use another brand available locally without a trip to a Mopar dealership?
Thanks Mike
Old Mar 18, 2011 | 09:39 AM
pdogg's Avatar
I use valvoline ATF+4... I usually buy about 8 quarts for a pan drain / refill. I installed a drain plug on my first change to make my life easier.
Old Mar 18, 2011 | 09:48 AM
jlipskoc's Avatar
ditto valvoline here to, autozone has it for $6.29 i think. change your power steering pump, and transfer case to, both take atf+4.
I've also seen +4 in castrol and coastal brands, walmart has it in the blue generic container.
Old Mar 18, 2011 | 09:50 AM
Dr.Dizzle's Avatar
MikeMotorhead,
You can use any of the licensed ATF+4 fluids illustrated on the following attachment.
http://www.centerforqa.com/licensedatf4brands.html
Old Mar 18, 2011 | 10:21 AM
surfram's Avatar
I use valvoline ATF+4. I used 6 quarts last time and it is right on full after a 20 mile drive, checked in neutral.
Old Mar 18, 2011 | 11:23 AM
Thanks for the quick reply's guy's
Mike
Old Mar 19, 2011 | 11:39 PM
NavyDood's Avatar
Napa ATF+4 is bottled by valvoline. $4.49 a quart.
Old Mar 24, 2011 | 07:55 AM
GSW's Avatar
GSW
This. I know around here that I save a buck and a half per quart by going with the NAPA brand.
Pig
23
Jun 4, 2010 01:01 PM
Mslaughter
Aug 24, 2006 06:44 PM
dieselfan
Aug 5, 2006 10:44 PM
Pig
Mar 13, 2006 09:12 PM
APD
Mar 6, 2005 07:57 PM
