Weird suspension/brake noise
Old Dec 28, 2023 | 06:44 PM
Barty's Avatar
Originally Posted by Mexstan
What is the year and model of your truck?
2003 2500 cummins. Just replaced the hydraulic line to the booster. No change.
Old Dec 28, 2023 | 07:01 PM
06Dodge250egaD's Avatar
BARTY - I just finally got my issue resolved. The SHIFT CABLE was rubbing the front drive shaft, but only when braking & when suspension was dampening for a pothole, etc.
1st attempt which helped a lot I simply used a zip tie to keep the shift cable from all that movement & flex. But it still made the noise on more extreme braking or suspension dampening.
Worth noting I never had this noise while driving or braking in reverse at any speed
2nd attempt which has completely eliminated the issue was to DISCONNECT THE SHIFT CABLE & REROUTE IT AWAY FROM FRONT DRIVE SHAFT
Hope this works for you & everyone else who has this issue
Old Dec 28, 2023 | 07:02 PM
Old Jan 19, 2024 | 09:36 AM
Barty Did you try the zip tie on shift cable or rerouting the shift cable to avoid it from hitting the drive shaft on braking & bumps? Did it work? You should let a comment on this forum for all to see
Old Jan 19, 2024 | 09:38 AM
Barty, did you try what I posted on 12/28/23 @ 8:01 PM ?
glowball
Aug 15, 2011 08:58 PM
jeremy judge
Feb 11, 2008 12:21 AM
bierk76
Jan 2, 2007 10:55 AM
Drafter
Dec 11, 2005 04:08 PM
Relentless
Oct 16, 2003 05:52 AM
