Weird oil leak at rear slip yoke
Old Sep 1, 2010 | 10:22 PM
Gen3cmmns's Avatar
What do you guys think about just welding it in? I really dont want to just drop $200 or so on a new slip yoke just so it can happen again. I talked to a freind of mine and he said this is called "hydraulic ing" they use the same principle to remove a bearing if they cant get a puller on it by forcing oil behind the bearing to push the bearing out.
So what is happening is, behind this cap is filling with atf and then when you compress the suspension it is forcing the slip yoke closer to the transfercase and pressurizing the atf behind the cap eventually causing it to leak.
So why not weld it in? Does it need to be removable for any reason?
Old Sep 1, 2010 | 10:26 PM
Lonewolf039's Avatar
LOL, I've been thinking about that as well. I really hate oil leaks
The only problem I can think of is maybe distorting the yoke from the heat of welding. Might be worth a try.
Old Sep 1, 2010 | 10:39 PM
torquefan's Avatar
I've seen this leak a few times, it seems pretty common on third gen trucks. If you can remove all the oil and rust around the parting line, apply some JB Weld over top of the area, then give it 24 hours to cure. That usually fixes it up.
Old Oct 13, 2010 | 07:25 PM
captjack's Avatar
Did the yoke and seal with new replacement and the Tcase tail shaft bushing found out this is common problem to fix the leak you must do the bushing al though their is an after market Co. doing a great mod. with a bearing replacement and flanged fixed yoke
Old Oct 13, 2010 | 08:33 PM
Who is doing the slip yoke eliminator? I would love to get rid of the entire slip yoke on the tcase.
Old Nov 1, 2010 | 12:17 PM
VaultRam's Avatar
What did you use to pop the plug on the yoke, socket extension and a hammer? What did you use to press it back together, just tapping it with a hammer? Just replaced the t-case seal but its leaking a little out of this cap too.
Old Sep 4, 2012 | 04:00 PM
robby t's Avatar
i have the same problem.....any chance you can post those pics? cant see them......thanks
Old Sep 4, 2012 | 05:02 PM
BigIron70's Avatar
Cummins Guru
Replace the front yoke, u-joint and seal.
Old Sep 5, 2012 | 07:58 AM
jhenson's Avatar
I fixed mine a year or so ago with a new slip yoke from Sadler Powertrain (very helpful and cut me a good deal) and had a friend of mine (professional welder) weld up the plug on the back. No leaks at all.
Old Sep 5, 2012 | 08:55 AM
robby t's Avatar
hey thanks for the info.....i think i'll weld the plug.....
Old Sep 5, 2012 | 10:49 AM
jhenson's Avatar
Guessing that all of these yokes have the damper pressed onto them.....keep a wet towel around the plug while doing this to avoid melting the rubber out of the damper.
m3rd
Sep 15, 2013 10:50 PM
perk
Aug 25, 2009 07:22 PM
dieselcarpenter
Sep 18, 2007 06:01 PM
TE-44
Aug 8, 2006 11:44 AM
Holsteinman
Apr 8, 2005 03:15 PM
