Waterpump took a dump
Old Dec 2, 2006 | 06:44 AM
Chip's Avatar
Anybody had their waterpump fail ? Waterpump is or is not covered under 5yr/100k engine warranty. What are your experiences ?
Old Dec 2, 2006 | 09:41 AM
HorseHauler's Avatar
i had mine replaced on my 03 at about 30k miles. everything was fine, it was just wet and had the dealer replace it. It should deffinately be covered under powertrain. how many miles do you have?
Old Dec 2, 2006 | 09:43 AM
elirandolph's Avatar
how did you know it went out? did it start overheating or leaking water out or what?
Old Dec 3, 2006 | 06:46 AM
Chip's Avatar
I just rolled over 60k. No over-heating- what happened was, I had slowed down to 5-10 mph to make a sharp rt hand turn, when I accelerated out of the turn, I heard something vibrating under the hood and felt the vibration in the steering wheel and the go pedal. I didn't by any means accelerate too hard. Vibration, for the most part, went away as I kept accelerating. Got home in the pm and when I shut the truck down, I was walking around the front and smelled a slight anti-freeze smell. Well, I opened the hood and looked around and saw anti-freeze on my intake housing and all around under the pump. I also grabed the pump pulley and gave it a slight yank up and down and could feel the play in the pump. It is covered under warranty and no deductable. Only after 5 years does the deductable kick in.
Chip
Old Dec 3, 2006 | 07:15 AM
PourinDiesel's Avatar
How can it not be covered?
Ask the dealer if they would like a bad engine to replace or a bad water pump?
Old Dec 3, 2006 | 08:43 AM
elandon1201's Avatar
Same thing happened to me, you better check on how much the part is. In my case the water pump was 70 bucks, and the powertrain warranty has a 100 dollar deductable so I just fixed it. A 5.9 has to have the easiest water pump to replace I have ever seen, its only two bolts. If you dont have a deductable send it in, unless its going to take a long time.
Old Dec 3, 2006 | 11:33 AM
Chip
Are you guys reading the same thing i am reading?????
Old Dec 3, 2006 | 06:46 PM
RonP's Avatar
I just had mine replaced and it is very clear in the warranty book. The water pump is covered on the diesel warranty and it is 5years or 100,000 miles. I paid nothing at all. Mine started squealing bad and then it stated leaking.
good luck
Old Dec 3, 2006 | 07:33 PM
dieselfan's Avatar
my dads 03 3500 drw crapped out at 135k earlier this year.
left him on the side of the road and cost him about $350 for roadside to come out and do it.
i also noticed most that crapped out are 03's.
dieselfan
Old Dec 4, 2006 | 08:35 AM
Chip's Avatar
Dropped truck off at dealer on Sat. Warranty covers everything except a rental car !!! While I was there, I noticed an 04 3500. Quad, DRW sitting on 22.5 alcoa's with a 6 in. lift, with 52k on the odo and completely stock. I walked over to the truck which had its hood open. They had the head pulled so I proceeded to ask the mechanic what was up. The mechanic said that something must have got sucked in the engine through the intake and scored the #3 cylinder. He said that the customer was going through 5 qts. of oil every 2 hrs. comming from puke tube, on his way back from Florida, not hauling anything. He is getting a whole new engine from Cummins.
Chip
Old Dec 7, 2006 | 06:44 AM
Chip's Avatar
Well, I get my truck back from the dealer, I get half way home and the truck starts running hot, almost in the red, dealer tows me back to dealership. Wonder what's up
Chip
Old Dec 7, 2006 | 08:15 AM
RonP's Avatar
Low on fluid maybe? the waterpumps on these couldn't be any easier to change than they are. I can't imagine someone screwing that up. 2 Bolts and the dang thing uses an o-ring. Hope they get it fixed for you.
Old Dec 7, 2006 | 11:16 AM
Kampnnut's Avatar
Sounds like they didn't burp the system. It is very easy to have trapped air in the system after refilling the radiator.
Old Dec 7, 2006 | 03:24 PM
mine did the SAME EXACT THING! something to do with the thermostat and ended up having to replace it. that or the air in the system
Old Dec 7, 2006 | 05:08 PM
Chip's Avatar
Got the truck back and yep, she needed to be burped. All is well so far. Thanks for the replies !!
Chip
johnny5.9
May 7, 2015 10:43 PM
capt.Ron
Feb 25, 2014 07:52 PM
narleycharlie
18
Sep 5, 2010 08:39 AM
Turbo Deeezle
Jun 4, 2005 08:49 PM
Tommy93w350
Jan 11, 2005 08:22 PM
