water pump
Old Aug 1, 2007 | 11:07 AM
shineboy2's Avatar
water pump
My dad has the same truck as mine, only a 3500 Dually. He was taking (1) steer to the butcher yesterday w/ the gooseneck, truck got really hot. He stopped, I guess there was water all over the front of the engine. He put water in it, temp went down. He took it to the dealer, they think it's a water pump, but will know for sure later today.
Anyone else have one go bad?
Old Aug 1, 2007 | 03:29 PM
wlewis's Avatar
I replaced mine at 104,667. Coolant was being pressured by the shaft seal behind the pump pulley and getting blown all over the engine compartment. New one from Cummins Southern Plains, a little time to install and all is well.
Old Aug 1, 2007 | 04:20 PM
3ton1/4's Avatar
covered under warranty if less than 100,000 miles, mine was. went out at 76,000.
Old Aug 1, 2007 | 05:00 PM
Roperteacher's Avatar
I had three go out on my 06 prior to 17,000 miles... Seems like a LOT of 06's had water pump problems!
Old Aug 1, 2007 | 09:21 PM
shineboy2's Avatar
Yep, Dad's has 50K on it... it was covered and he got it back today.
Old Aug 2, 2007 | 12:55 AM
TrkEnvy's Avatar
yup.. my waterpump on my 06 went out at 16,000 and it took 2 trips to the dealer to find out why it was getting hot and losing coolant..
Old Aug 2, 2007 | 01:36 AM
dogger's Avatar
Go figure
If the service personnel can't plug an electronic diagnostic tool into the port chances are they will not find the problem even if the floor is covered with oil from a hole in the oil pan. Suggest you find a service guy over 50.
L8r,.........dogger
ted_pulliam
Oct 15, 2009 08:24 AM
RamWheelsBy4
Apr 11, 2007 04:43 PM
kev211
14
Feb 22, 2007 03:39 PM
Gene Peterson
Jan 7, 2006 02:32 PM
