Water Drain not Draining
Old Sep 23, 2007 | 07:56 PM
Mark Hodowanec's Avatar
Changed out the fuel filter today. Opened up the drain valve & nothing came out. Pulled filter, & filter canister full of fuel. Replaced filter, cranked up motor & opened up valve - only a tricke came out. What gives?
Also, when I pulled the filter from the cap, the plastic part of the filter that snaps into the cap stayed w/ the cap. It's like the filter came apart. Makes me wonder if it were coming apart for a while now.
Finally, what is the fuel flow thru the filter - does the fuel come in the center of the filter & get pushed to the OD or the other way around. Also, the fuel that stays in the bowl - will it be refiltered, or is it already filtered & on it's way to the CP3?
Old Sep 23, 2007 | 09:58 PM
Roperteacher's Avatar
NOt sure why your canister didn't drain. Mine always do. I believe the fuel comes UP the stand pipe then OUT through the filter media. Any fuel left in the canister is UNFILTERED and headed for the CPS... I have never heard of it not draining...
Old Sep 23, 2007 | 11:19 PM
Prodart440's Avatar
I changed my fuel filter about 1 month ago. Opened the drain and nothing. Pulled the filter and all the sudden it started to come out. Don't know what it was, but nothing was in the canister.
Aaron
Old Sep 24, 2007 | 01:06 AM
danc46's Avatar
Unscrew your fuel filter lead, break the suction in the housing, before you open the water drain, so it will flow when you do.
Old Sep 24, 2007 | 03:54 AM
Are you talking about the filter cap? I thought that the water drain was supposed to drain even when you werent changing the filter?
Old Sep 25, 2007 | 05:15 AM
I'm going to remove teh drain valve & clean it. Anyone have any directions for removing it? Does it seal w/ a gasket or o-ring. I'm thinking that I can reuse an o-ring, but where would I get another gasket?
Old Sep 25, 2007 | 09:58 AM
Grey Wolf's Avatar
Fuel flows through the filter from the outside to the inside...
miketriton
15
Jan 16, 2009 05:24 PM
Mark Hodowanec
Sep 25, 2007 05:16 AM
2002cumTRBODSL
Dec 20, 2005 11:51 PM
Cargun
18
May 8, 2005 10:01 PM
wooff
May 1, 2003 11:22 AM
