warning beep/ engine light/ loss of power
Old Oct 7, 2009 | 02:33 PM
huron52's Avatar
Driving down a paved highway, about 95kph (less than 60mph) No change in throttle setting by me. The warning beeps once, the engine light comes on and it start stumbling. Feels like it is not running on all cylinders. Very slow to respond to throttle change. no really power.
I tried to get the codes via turning on the key three times but nothing would show. Did the guage code trick and got a C447 , C 127 and something that looks like .285
oil pressure is ok, temp is ok, voltage is ok It starts and runs but not good.
What happened? What should I look for?
Old Oct 7, 2009 | 02:51 PM
BigDiesels's Avatar
That sounds like what happened when I lost #6 injector and the rear injector harness. It threw codes though (can't remember the #'s) but those were the symptoms. Apparently, sometimes the harness that runs through the valve cover shorts out and may take injectors with it.
Old Oct 24, 2009 | 01:56 PM
huron52's Avatar
I got the truck into the garage and the code reader said that there was a misfire on number 4,5 or 6 cylinder. It ran good went I took it in. Couldn't get the truck to reproduce the problem again.
The mechanic said something about the cover gasket maybe shorted out
Not sure what to do... I guess I will have to wait until it does it again.
Old Oct 24, 2009 | 02:08 PM
tryNto's Avatar
I would say he got it right...
Old Oct 24, 2009 | 02:18 PM
rich's Avatar
yea sounds like it seems to get more and more common in the late 06 and early 07 5.9
Old Oct 24, 2009 | 03:58 PM
Topper's Avatar
Had the same problem with my 06. They have come up with a new valve cover gasket, should take care of it.
good luck,
Topper
Old Oct 24, 2009 | 09:27 PM
Ridgeman's Avatar
I had those very same gage codes when I checked the c codes. They were not on any error code list I could find. I took mine to the Dodge dealer last Tuesday to check it out. They said they were codes the software engineers use for the programs. I don't have any symtoms so I guess it is OK.
I was just trying to get all the bugs fixed before my warranty expires on the 27th. While they had my truck plugged in to check codes and give me the latest flash they apparently fried my key so it wouldn't start my truck any more. Said they tried to reprogram it but it wouldn't take. So they reprogramed my spare and ordered me a new key on their nickle. So when I arrived at the dealer I apparently had no problems. Three hours later I was going home with a fried key and a promise to allow me to come back again (60 miles RT ) to get a new key programed and cut. Scary isn't it?
RHC
Aug 12, 2019 03:32 PM
dodgebob03
May 21, 2014 07:43 PM
exwrestler
Dec 24, 2013 09:22 PM
Clane
Sep 6, 2009 09:18 PM
PK
May 8, 2006 04:54 PM
