2500 Leaf Spring
Old Oct 22, 2009 | 10:38 PM
cinch_55's Avatar
2500 Leaf Spring
I have a 2500 and am going to put a 2.5" leveling kit on it. I was wondering if I could swap a set of 3500 leaf springs with mine to get the rear end up after I lift the front. The whole suspension is tired due to many miles. It would also be nice to beef up the truck as well.
Old Oct 23, 2009 | 03:36 AM
annabelle's Avatar
My neighbor did with his.
Old Oct 23, 2009 | 05:57 AM
DR3500's Avatar
won't gain any height other than what little bit you will get from springs that haven't sagged yet.
Old Oct 23, 2009 | 08:33 AM
HOBrian's Avatar
Springs are the same there is no difference, don't waste the time!!
Old Oct 23, 2009 | 08:35 AM
cinch_55's Avatar
Aren't there more leafs on he 3500?
Old Oct 23, 2009 | 11:13 AM
efil4ynot's Avatar
I'm pretty sure that the only difference is the overload spring, which is located on top of the spring pack so it won't increase the height.
Old Oct 23, 2009 | 12:04 PM
13MWZ's Avatar
Yup, that's the only differance between a 3500 and 2500 period, unless of corse the 3500 is a dually, then it's just a longer rear axle with bolt on hub extentions up front. Oh yea, and the rear fenders lol.
But yea, doing that would be a wast of time and money.
Old Oct 24, 2009 | 05:06 PM
cromulius's Avatar
Put on a set of constant rate overload springs. I had some on the z71 and it brought it up a couple inches. I believe they were helwig. Easy install with u bolts took ten minutes per side.
Old Oct 24, 2009 | 10:06 PM
alboy's Avatar
Some 2500 ,s don,t have the shims under the rear spring pack,approx 1 3/4 inches as per all 3500,s have them.
ogopogo
Apr 11, 2013 07:15 PM
97catintenn
May 28, 2010 08:29 PM
smokinram99
Feb 27, 2008 01:42 PM
Joe T
16
Jun 12, 2007 12:11 AM
