want to drop rpms
Taller tires above 285 would not work for me due to pulling horse and stock trailers alot. I went with the 3.42 gear change and have been fully satisfied. Did it in December 2007. It was pricey at $1900, but hand calulated I picked up 1.5 mpg in town and 2 on the highway. I also can run 70 at 1950 rpm where before it was 2150 with the 285's. 5th gear is now usable for 55 mph ranch roads and extra heavy loads. It will take about 50,000 miles to pay for itself, but the truck is just more of a pleasure to drive. However, if I had a NV5600, post December 2007 G56, 48RE or a 68RFE I would not consider it because you would then drop rpm's too much if the truck is used for work. Just my 2 cents. Jay Jones
If you can, the larger tires seem to be the most inexpensive way to go, though for the old dually you are looking at getting 6. You can also look at a gear vendors unit, but they are fairly pricey.
Problem with this tire is it is VERY heavy.. stock 265's are 48lbs, toyo 285/70 are 53lbs, and the 285/75's are a whopping 67, almost 20lbs a tire heavier than stock... Thats 80lbs in extra unsprung weight, which is HUGE when your trying to drop rpms for mileage. From what I have read the rpm drop mpg increase in negated by the tire weight increase, so your back at square one.
jschintgen
Dec 31, 2009 11:17 PM
sallyman1
Jan 2, 2009 12:32 PM
roughstock
Mar 27, 2008 01:57 PM
