Wanna see death wobble?
Old Mar 26, 2007 | 11:29 AM
ptgarcia's Avatar
Check these new videos on Don Thuren's website:
http://thurenfabrication.com/misc.html
Old Mar 26, 2007 | 12:25 PM
FishingFather's Avatar
Holy cow! That is truely scary!
Old Mar 26, 2007 | 12:37 PM
bigdav160's Avatar
I'm a little disappointed in the camera angle. From that vantage all the shake appears "at the tire". I don't see that lateral movement in the axle that the track bar is suppose to control.
Old Mar 26, 2007 | 12:50 PM
Rambunctious1's Avatar
That SUCKS!!
Old Mar 26, 2007 | 01:27 PM
nfsommer's Avatar
wow..........................
Old Mar 26, 2007 | 01:31 PM
madhat's Avatar
Administrator/Jarhead
That is sick!!! Glad I don't have that problem. What is the deal with that? What causes it?
Old Mar 26, 2007 | 02:07 PM
vegashd's Avatar
usually an untorqued trac bar. That has been my experience with it.
you dont see the axle as it really can only move a TINY bit, but it is enough to make you feel it. its scarier then crap. It will rip the steerin wheel right out of your hands. The steering wheel moves back and forth faster then you can imagine. Every time it happened ot me I had to come to a stop to stop it as holdi the steering wheel only made it worse.
Old Mar 26, 2007 | 02:18 PM
dodgechick98's Avatar
Yeah losing control is scarier than heck. My 95 gives me problems occasionally- i've changed out the shock, tie rods, trac bar....still giving me fits.
Old Mar 26, 2007 | 02:33 PM
chromegrill's Avatar
Thats because you won't see lateral movement in the axle, like you said the track bar is controling it, plus thats not what DW is. The only way you can have a DW issue is worn suspension parts, or improper caster angle. You lift a truck like these and right away you have decreased caster angle. These things need as much positive caster as possible. People like to blame DW on tires which cracks me up.
Old Mar 26, 2007 | 03:48 PM
welndmn's Avatar
Loose parts causes death wobble.
The EB in video had little to no Trac Bar bushings IIRC.
Old Mar 26, 2007 | 04:13 PM
ptgarcia's Avatar
What's an EB?
Christ, doesn't anyone spell words out?
Old Mar 26, 2007 | 04:52 PM
OR Mega Cab's Avatar
Early Bronco?
Old Mar 26, 2007 | 05:13 PM
Boz007's Avatar
Originally Posted by ptgarcia
What's an EB?
Originally Posted by OR Mega Cab
Early Bronco?
Yeah Early Bronco.
Death Wobble is caused by a number of things. The most common seems to be a worn out track bar. But bad ball joints, bad control arm bushings, or not enough caster can also cause it. Don did that on purpose if i recall to show what it looks like.
Old Mar 26, 2007 | 05:25 PM
JWillms81's Avatar
That slow motion one shows it the best, you guys are right about it being scarier then heck, mine used to do it about 2 years ago, glad I didnt see that video back then dont think I would have taken the truck on the highway after seeing that.
JW
Old Mar 26, 2007 | 06:12 PM
bigdav160's Avatar
Keep laughing.
My .03 had severe death wobbles with BFG's. Just any good size bump would set it off.
New tires and not one episode since (almost two years now). Same roads.
Tires seem to have fixed mine.
