Vibrations - Dodge's problem
Old Jan 13, 2005 | 12:37 PM
  #31
kry226's Avatar
I have 4.10s and had the thrumming with stock tires/coils. Put the 315s and TRex/KORE coils on and thrumming has evolved into a shimmy at the same rpm/speed.
Old Jan 13, 2005 | 12:42 PM
  #32
NJMurvin's Avatar
I have 3.73s and mine starts the vibe at around 68mph. I can put it in neutral and coast at that speed and still vibe, so it's not an engine RPM vibe.
Dumb question . . . Is the front diff the same regardless of ratio (3.73 vs. 4.10)? Whenever I read about changing ratios, only the rear diff is discussed. I makes sense that both would have to match in a 4x4.
Neil
Old Jan 13, 2005 | 01:09 PM
  #33
bigblock2stroke's Avatar
the front diff ratio must match the rear diff ratio. It would work until you engaged 4WD. Then all hell would break loose
PapaPerk
Mar 17, 2005 08:40 AM
030303
Dec 15, 2004 06:34 PM
TurboTed
Sep 2, 2004 08:28 AM
Todd Hoffman
Mar 31, 2004 07:52 PM
Paul S.
Mar 31, 2003 08:59 AM
