vibration at idle??? 6 spd
Old Oct 20, 2011 | 02:35 PM
Bret66's Avatar
Hey need a little help, Ive searched the forums and havent found anything to help me out. I have noticed a vibration at idle, doesnt matter if you have the clutch engaged or not. it goes away once its in gear on moving..
Ive got an 06 megacab 6 speed with 153,000 miles on it. clutch seems good,
any ideas??? friend drove it and said it sounded like throw out bearing..
Havent had a manual in 15 yrs.. so any help would be appreciated..
Thanks
Old Oct 20, 2011 | 02:52 PM
jhenson's Avatar
If you have the G56 tranny there's a good chance it's the dual mass flywheel. Most all of them have taken a dump on their owners at some point.
Just my .02
Old Oct 20, 2011 | 04:42 PM
wshamby01's Avatar
If I were betting it is the flywheel. That is a lot of miles for a DMF. I have seen several failures at way less miles.
Old Oct 20, 2011 | 05:51 PM
ECSelner's Avatar
Sounds exactly what i had when my flywheel went. Once we had the pressure plate off you could free spin the thing about 1/8 of a turn before it would catch the springs. Horrible design from a longevity point of view but it does lessen the vibration a bit in the drive train (when not messed up), I switched it out for a single mass. Yeah they are a bit noisier at lower rpms but i can't see dropping in a new flywheel every 75k.
Old Oct 20, 2011 | 06:02 PM
Bret66's Avatar
Thanks for the help guys.. Ill check it out..
Old Oct 31, 2011 | 09:30 PM
horsehelper's Avatar
I had this issue and it was my harmonic balancer. The bolts started to come out and throw everything outa wack. Good luck
Old Oct 31, 2011 | 11:17 PM
gadget.35-06's Avatar
The G56 also has a very long pilot diameter on the input shaft---long enough that I found my pilot bearing backed ALL THE WAY out of its bore; there was lining dust all over the bearing outer race indicating it was completely out. The new bearing, on my Valair, is staked in place.
Old Nov 1, 2011 | 04:37 PM
Bret66's Avatar
Thanks, How are you liking the Valair?
Old Nov 1, 2011 | 11:29 PM
Floater plate's noisy but me likey da dual disky!!!!! And the noise is no worse than typical diesel clatter so you get used to it.
mxmike27
Nov 5, 2009 03:00 PM
pmtg
Sep 7, 2006 11:54 PM
raybob_99
Apr 4, 2006 04:31 PM
NCTURBOS
18
Oct 29, 2005 12:07 PM
