Verdict For Failing To Fix Known Transmission "Park-to-Reverse'' Defect
Old Mar 12, 2007 | 10:57 AM
  #31
Toto's Avatar
I always use the "parking brake".
For safety reasons and to prevent brake cable freeze up.
As others have said, very few folks read their owners manual.
There is a wealth of info in there.
I read it because I am a bit of a gear head and I find good info in there.
Most folks would find it boring.
Perhaps the manufacturers should include a DVD with the manual as folks may be a little more compliant with this format...who knows?
Old Mar 12, 2007 | 11:29 AM
  #32
cskal's Avatar
Did the truck in question have rear disc or drum? I seem to remember that drum brakes by design would allow a vehicle to roll (drive) backwards with a minimal input of force (idle in reverse) regardless of the parking brake being engaged or not; you just could not roll/drive forward without significant force. I am assuming that the vehicle had rear disc just because of this.
Old Mar 12, 2007 | 12:16 PM
  #33
carpenterje's Avatar
I've been laughed at for using my parking brake on an auto. Better to be safe than sorry. But being said, I have had the problem when I go out to my truck to start it and it won't start because on the shift lever it says it's in Reverse, when I grab the lever to pull it up to park it won't go any further up. So I have to jiggle it around so it shows it is in park, then it will start-up. Remind you I have already had the parking cable lever and parking paw replaced once before cause truck got hung up in reverse and wouldn't even come out of reverse to where I had to have it towed in to get fixed.
fredbert
379
Aug 17, 2011 11:52 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
pet05
Jun 25, 2006 03:21 PM
hogheaven
Sep 1, 2004 01:55 PM
Shovelhead
Nov 25, 2003 02:04 PM
