Valvoline Premium Blue and CJ-4
Old Jul 23, 2008 | 08:34 PM
estesbubba's Avatar
I just bought some Valvoline Premium Blue oil. After reading a lot of CJ-4 vs. CI-4 discussions, it appears the CI-4 has the red label and CJ-4 has the blue label. Well, mine has the blue label (no red at all) but the back says exceeds CJ-4, CI-4, CI-4 plus, etc. The Valvoline site definitely shows the red label. I wonder what exactly I got?
The important question is do I stick with the same 7500 oil changes as in the past? All my past oil analysis have come back fine.
Old Jul 23, 2008 | 08:43 PM
MikeyB's Avatar
It's the CJ-4.
You should be safe at 7500 but if in doubt do an oil analysis at 5k.
MikeyB
Old Jul 27, 2008 | 07:53 PM
WhoozYaDaddy's Avatar
Red label is 5w40 Premium Blue Extreme Synthetic. It is only CI-4+ rated. It has not been reformulated yet. Blue label is Premium Blue 15w40. If it says CJ-4 on the back then it can go in new diesels as well. It is backward compatable with CI-4+, treat it the same.
Old Jul 28, 2008 | 01:40 AM
Mr. Big Ram's Avatar
I just bought a couple dozen gallons of PB... the CI-4 stuff. the new CJ stuff also comes in a diffrent looking jug. Look at the donut on the back label, it will have either CI-4 or CJ-4 in the bottom half.
Old Jul 28, 2008 | 09:24 AM
Roperteacher's Avatar
Unless you got real lucky, the CI4 should be long gone. You can still get it in 5 gallon cans, but not the gallon sizes. If you look real close, the CI4+ is prominantly displayed but the CJ is smaller.
If your oil part # is 70509 then it is CJ
Old Jul 28, 2008 | 10:56 AM
Cinci Diesel's Avatar
I believe the CJ will have the starburst around it, all of the CI-4+ that I buy does not have the starburst and they will tell you to check you manual for warranty issues with the CI-4+ even though I only use CI-4 and never any warranty problems. Anyway the CJ should have the starburst witch basically means you should be able to put it in anything with no warranty problems.
Utundra
Aug 9, 2009 11:07 AM
Dynocon
15
Jul 5, 2008 11:10 PM
popeye
93
Dec 26, 2003 01:08 PM
Tartarus
Dec 7, 2003 11:59 PM
latitud_rt
Oct 12, 2002 07:08 AM
