valve adjustment.
Old May 13, 2015 | 11:49 PM
Sawyer1's Avatar
Question valve adjustment.
I see all these DIY writeups for adjusting the valves on a 24v but no where do I see any mention of checking the cross heads or bridges. Are they not adjustable as they are in the bigger diesel engines and if not can you get adjustable cross heads so you can keep everything to proper specs instead of just a hit and miss?
Old May 14, 2015 | 09:10 AM
soulezoo's Avatar
DTR 1st Sergeant
The bridges are not adjustable in and of themselves. Because the center sits on a ball from the rocker, downward pressure from the rocker is evenly distributed all other things being equal.
In all the valve adjustments I've done... and I am really finicky... I have never experienced "hit or miss". They adjust well and stay that way. Cummins recommends adjustment after 100,000 miles IIRC. Many people have experienced no adjustment necessary or just very small tweaks at that interval.
IMO, there are enough other things to worry about than adjustable bridges in the valve train. A non-issue to me.
Fishbait
Nov 23, 2009 11:21 AM
ConnerCop
May 5, 2009 07:48 AM
dhughe2
13
Dec 6, 2006 07:40 AM
bulthisl
Mar 22, 2003 07:01 AM
blackboat
Nov 8, 2002 06:32 PM
