Valve Adjustment
Old Mar 15, 2011 | 08:01 PM
Sur5er's Avatar
Valve Adjustment
Did the deed with 97,500 on the odo. Intakes were fine at .009", across the board, the exhausts, were a different story. Everyone of them was way too loose. At first I thought I used the .010" gauge it was so sloppy. Most needed almost 1/2 of a turn CW to close the gap to .020". Runs a lot quieter at normal idle, but the auto up to 1000 RPM shows a more pronounced lope than before, but without the clatter. That #6 is a real PITA to adjust. BTW, the cover had not been off before. 15mm deep socket on the crank damper was a lot easier than I thought it would be even with the SBS. You can use a 3/8 drive ratchet and she will turn over just fine.
You may want to mark the bottom of the damper with an "X" once you have TDC aligned on top. That way all you have to do is rotate the damper until you see the X again and you're all set to do the other valves.
Old Mar 16, 2011 | 06:39 AM
MikeyB's Avatar
Great tip!
MikeyB
Old Mar 16, 2011 | 08:31 AM
soulezoo's Avatar
DTR 1st Sergeant
If this is the first time you have touched the valves on your truck, that "looseness" you felt with the .020" feeler was normal....
in '06 the spec on the exh valve was changed to .026" to provide more seat dwell for heat transference from valve to head.
You're ok at .020" so don't worry, just thought you'd like to know your valves were ok where you found them.
Old Mar 16, 2011 | 10:16 AM
carl48's Avatar
i changed cams in my 06 and set the exhaust at 0.020 for about a month before i seen on the plate to set it at 0.026 i changed mine to the speck. after reading soulezoo i may want to change back to 0.020 with the cam and smarty jr i no longer have the high heat.
Old Mar 16, 2011 | 07:53 PM
Bark's Avatar
Thanks for the post! On my 03 should I still go for .020 on the e-valves or shoot for .026?
Old Mar 16, 2011 | 09:15 PM
Sur5er's Avatar
I don't want to nit pick, but even if the spec was changed to .026, mine were not OK. You could hear them clatter under load. #6 was especially loud. Like I said, they took almost 1/2 turn to close the gap to .020". Assuming the rocker stud is 8 X 1.25, then each 1/2 turn would be .625mm or .0246". That means that the exhaust valve lash was roughly .044" so they were off by .024". I think I'll be checking them again in 10,000 miles.
Old Mar 18, 2011 | 10:42 AM
soulezoo's Avatar
DTR 1st Sergeant
Stay with the .020... in fact, you can take it down a little tighter and see just a tad better spool. (gives a little more duration)
Old Mar 18, 2011 | 03:20 PM
Bark's Avatar
Thanks!
Fishbait
Nov 23, 2009 11:21 AM
ConnerCop
May 5, 2009 07:48 AM
dhughe2
13
Dec 6, 2006 07:40 AM
bulthisl
Mar 22, 2003 07:01 AM
blackboat
Nov 8, 2002 06:32 PM
