Unplugging the EGR
Old Dec 24, 2010 | 08:43 PM
brophyn70's Avatar
Unplugging the EGR
will unplugging the EGR trigger the check engine light?
Old Dec 25, 2010 | 07:05 AM
DJM's Avatar
DJM
YES, plug in back in and the check engine light goes out after a couple (four) turns of the key
Old Dec 25, 2010 | 07:18 AM
New2Diesel's Avatar
"Gomer Pyle"
I have a 2011 and unplugged it. TERRIBLE IDEA. Truck ran like garbage and got terrible gas mileage despite what I have read. Plugged it back in and after several starts the light went out. Also, from what I was told by one of the very smart Diesel companies, I should not unplug just get a tuner that turns off the EGR system and do the deletes. The only reason I even tried to unplug is because I thought I could get a couple more miles to the gallon. That was not the case. But, since it does not hurt anything, you could try and maybe get better results than I did.
Old Dec 25, 2010 | 07:37 AM
DJM's Avatar
DJM
I tried it, was so simple to unplug & I saw an increase of 2.5 to 3 mpg, according to the on board computer.
I don't know if it was related, but shortly after plugging it back in and the check engine light went off, the oil change message appeared, had the oil changed and the were unable to clear the message & had to replace the "cluster" which is apparently a computer system in the truck. Not sure if the un plugging was related to the computer failure or not.
Old Dec 25, 2010 | 07:44 AM
New2Diesel's Avatar
"Gomer Pyle"
My digital computer was showing an similar improvement in gas mileage, but that was not the case. It was way off, reading 16.8mpg on an entire tank with a hand calculation of 12mpg. As far as the cluster needing to be replaced, I doubt it was tied to unplugging the EGR.
GMScott
418
Jan 21, 2012 03:46 PM
TheOutdoorsman
Jul 5, 2009 08:12 AM
armourbl
Apr 16, 2009 03:00 PM
bstiger
16
Dec 20, 2008 01:03 PM
38short
25
Nov 28, 2008 09:46 AM
