how do i clear codes
Old Dec 24, 2010 | 06:56 PM
stealman1's Avatar
I have a 04.5 with the 48re trans. Which is stock. I am getting the p1740 code. I read on here that it has to do with the transmission. I want to clear the code and see if it comes back. Is there anyway to do this without a code reader or performance programmer? I went to a O'Rileys and they said they don't do it anymore. I tried disconnecting the batteries and it did not work. Maybe the batteries need to be disconnected for a certain amount of time?
Old Dec 24, 2010 | 07:11 PM
madhat's Avatar
Administrator/Jarhead
Try disconnecting the batteries for 20 minutes, before you hook them back up, turn the key on and press the brake. (should ground out the system)
I know Autozone will still clear codes.
Where are you located? See if someone around you has a smarty, they can do it easy.
Old Dec 24, 2010 | 08:27 PM
stealman1's Avatar
Thanks for the help. I will try leaving the batteries unhooked for a while. And if this doesn't work I will go to a Autozone.
Old Dec 24, 2010 | 08:57 PM
Gitch's Avatar
the batteries unhooked did not clear mine. It actually threw more. Because the ecm will loose contact with certain parts of the truck. For me it was abs light and sim key or something like that. Autozone where i do live does not clear. But advance auto does.
So you kinda gotta find out who will do it. In michigan neither would do it. Unless i pushed the "delete Code" button.
Old Dec 25, 2010 | 09:22 AM
stealman1's Avatar
OK Thanks for that info. I live in Lake Tahoe Ca. Does anyone know who will clear codes for free in Lake Tahoe, Reno nv., or Carson city?
And where is the connection for the scan tool?
Old Dec 25, 2010 | 09:43 AM
johnh's Avatar
auto zone,o'reillys will.........by your knees as you are sitting in a driving position........some will hook up their scanner only if the ck engine lite is on
Old Dec 25, 2010 | 09:54 AM
madhat's Avatar
If you're my way...
The OBDII port is right next to the hood release.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
cmckinney
Aug 6, 2003 03:28 PM
hellotbone
Apr 1, 2003 03:11 PM
