Unknown problem... any ideas?
Old May 22, 2007 | 09:53 PM
vzdude's Avatar
DTR's 'Go to Guy'
If you have them put the greasable prescision ones in, then no. I would do these joints ALLLLLL day long for that kind of cash! Man! I just don't charge enough I guess. Not saying you got ripped off or anything, depends on the fair market labor prices around you. When you say "leaking" was the axle seal leaking, or the u-joint caps?
Old May 22, 2007 | 10:04 PM
kertoncol's Avatar
The u-joint cap was leaking. They charged me about 5.5 hours of labor @ $89 per hour.
Old May 22, 2007 | 10:17 PM
longbed's Avatar
It cost me 600 at dealer to change u joins. You didnt get ripped off. It looks like a pain to do in the driveway. I bought greasable ones but dealer said they can only install original parts.
Old May 22, 2007 | 10:37 PM
vzdude's Avatar
DTR's 'Go to Guy'
Last set I did, using the wheel stud trick, took me about 2.5 hrs to do both sides. That was not "busting my hump " either. Truck had 138k on the clock and had never been apart before.( good and tight!)
Dealer would only install their parts? , or wouldn't let you carry in parts? They should have been able to get the joints (greasable) from their local supplier. Oh well, just would highly consider it next time.
Old May 22, 2007 | 11:06 PM
torquefan's Avatar
My advice is to replace the AAM joints with Spicer NON greasable joints. I'm not a big fan of greasable joints at all. The non greasable joints have a much superior seal for keeping water out of the joint, and yes, you can add grease to a greasable joint any time you want to, but who's to say the grease is getting into ALL the caps? Quite often you can pump grease into the joint only to have grease appear at only two or three caps.
Old May 23, 2007 | 05:43 PM
kertoncol's Avatar
After taking the hubs out and pulling the axle with the ujoints, did you need to use a press to remove the ujoints?
Old May 23, 2007 | 11:15 PM
vzdude's Avatar
DTR's 'Go to Guy'
Nope, just remove the C- clips on the inside of the yoke, and beat them out with a hammer. After I put them in and all the clips, I make sure the caps are at the outermost position by gently beating them like I was trying to remove them to put the c clip right against the yoke. Doing this also helps to make sure that all 4 caps recieve grease.
Old May 31, 2007 | 03:37 PM
Buzzman's Avatar
Anyone's else experience this problem truck almost new and this is exactly the symptom I am experiencing just want to make sure it could not be something else than the u-joint .
Buzzman
6 Shaker
Jun 17, 2009 10:25 PM
Hooligan6
May 24, 2009 11:26 AM
bjwcattleco
Jan 9, 2008 12:19 AM
Hooligan6
22
Jul 17, 2007 11:41 PM
ViperSBT
May 21, 2004 07:41 PM
