Unknown steering problem
Old May 23, 2009 | 09:13 PM
Hooligan6's Avatar
Question Unknown steering problem
My steering pump was leaking a few days ago where the pitman connects. now when I'm driving and I turn to the left the steering wheel goes from firm to VERY loose to about 1/4 turn of the wheel then it becomes firm again. This only happens when I turn left while driving. I've almost ran off the road over correcting the wheel because of it.
I'm thinking the leak was the first sign of the pump going bad?? I've read several posts with several steering problems but nothing that describes my issue.
Any suggestions would be great!!
I will update my truck info I have way more done now then last time I was on here.
Old May 24, 2009 | 08:11 AM
Ace's Avatar
Ace
How's the fluid level? I'd put a new steering box on it if the sector shaft's leaking.
Old May 24, 2009 | 11:09 AM
BigDave12768's Avatar
My 02 did same thing. I threw some Lucas in it. Stopped leak. But still feels like steering should be a bit better
Old May 24, 2009 | 11:26 AM
BigIron70's Avatar
Cummins Guru
There is a recall on steering, you might want to check if your vehicle requires the recall to be done. Safety Recall H46 - Mopar Steering Linkage
bjwcattleco
Jan 9, 2008 12:19 AM
Hooligan6
22
Jul 17, 2007 11:41 PM
kertoncol
22
May 31, 2007 03:37 PM
ShowMe06
Mar 31, 2007 11:08 PM
ViperSBT
May 21, 2004 07:41 PM
