unexplained noise
Old Jun 26, 2011 | 09:03 AM
Reelay's Avatar
unexplained noise
When shifting gears at higher rpms like approaching a freeway ramp a strange noise comes from under the hood. Sounds as though it is coming from the turbo. Is this just the turbo spooling ? Seems to happen more frequently when pulling my fifth wheel. I have a 6 speed g56 with a new south bend clutch maybe 5k on the clutch I believe that the clutch is not the problem because the problem noise was there before the new clutch and the sound is from under the hood right front.
Old Jun 26, 2011 | 12:08 PM
Hodge's Avatar
The turbo always spooled- if this is a new noise, it is safer to assume that something has changed, than it is to assume that nothing has. I would pull be looking at the turbo since it is high dollar and under tremendous loads, and then go from there. New noises happen for a reason. Always explore them.
Smkn600CTD
May 22, 2012 07:21 PM
richie waddell
May 6, 2009 09:57 PM
mgood777
13
Dec 14, 2008 05:55 PM
ShowMe06
27
Jan 4, 2008 11:47 AM
Tackdriver
Mar 12, 2003 01:58 PM
