unexplained sound
Old May 6, 2009 | 07:53 PM
richie waddell's Avatar
unexplained sound
when i am pulling out sometimes and kinda laying into it if i let off of the fuel quickly before it shifts out of 2nd gear at somewhere between 15 and 20 psi of boost the truck will make a noise that kind of sounds like it is trying to relieve some back pressure or something it does not do it all the time but can make it do it pretty frequently any suggestions kinda lost
Old May 6, 2009 | 07:55 PM
carte89's Avatar
im guessing its your waste gate opening. kinda a shutter sound?
Old May 6, 2009 | 08:05 PM
could be but why should the wastegate be opening at around 20 psi
Old May 6, 2009 | 08:39 PM
TrkEnvy's Avatar
You are probably barking the turbo a bit when you back out quickly.. Air has no place to go but push back against the turbo wheel.
Old May 6, 2009 | 08:58 PM
what can i do to get this to stop because barking the turbo can't be good for it can it
Old May 6, 2009 | 09:03 PM
carte89's Avatar
rather than letting off the fuel really quick just let off smoothly? not sure if thats the right wording. but my truck will do it if i get in it a second or so then let off right away. so i have to feather it out
Old May 6, 2009 | 09:05 PM
will opening up the exhaust a little more by getting rid of the kitty help out any
Old May 6, 2009 | 09:57 PM
HotRodTodd's Avatar
Its kind of like the guy that went to the doctor and said,"It only hurts when I do this", and the doctor told him, "Just don't do that anymore".
It is a normal sound when getting out of the throttle while there is high boost pressure. Its not great for the turbo, but it won't kill it immediately either.
As was said before, just try and ease out of the throttle when possible, and no, opening up the exhaust won't cure it.
samiam4
Dec 19, 2012 12:08 PM
Reelay
Jun 26, 2011 12:08 PM
mgood777
13
Dec 14, 2008 05:55 PM
Clay
Mar 21, 2003 10:53 PM
MJR
Mar 16, 2003 08:26 PM
