Ujoints
Old Feb 17, 2010 | 06:25 PM
Shepherd57's Avatar
Ujoints
Dose anybody have the part number for the correct U-joints for the rear drive shaft on an 03 6 speed short box. The Neapco joint I got I can't get the clips in all the way.I read some where that there is a difference in the width of the cross on some of the u-joints
Old Feb 18, 2010 | 11:34 AM
slimpicken's Avatar
Dont have the part number but I'm pretty sure they are all the same part. Check to make sure one of the needle bearings didnt fall across the cap. I'vehad that happenbefore with the same results.
Old Feb 18, 2010 | 03:44 PM
Shepherd57's Avatar
The needle bearing wasn't turned over. But to get the clips in I had to grind
10 Thou off of each bearing cap.And I used the 351 u-joint what gives with these drive lines I shouldn't have to grind caps to get the clips in
Old Feb 18, 2010 | 06:40 PM
booman70's Avatar
I didnt grind em but they were really tight going together then just loosened up with a hammer I think they were 351s
joeel
Apr 5, 2007 01:18 PM
Ram1960
May 1, 2006 06:20 PM
OUTDOORSMAN
Aug 30, 2005 02:00 PM
CCOUGHRAN
Jan 4, 2005 10:10 PM
